Question about Canon PIXMA MP600 all-In-One InkJet Printer
Installed canon all-in-one now cannot connect to my network
I just installed a canon mp620 all-in-one. My laptop will connect to the printer, but will not connect to my wireless network. I have to use an ethernet cable to go on-line. What happened?
  • 2 more comments
  • cannon_311 Jan 12, 2009
    My wireless card is on. I tried turning off and on, did not work. Even tried restarting my computer. My laptop is a gateway M-series running windows vista.
    I figured it out. The software automatically assigned a permanent ip address. When I tried to go online, my computer tried to reset the address. I had to use advanced set-up in the printer and change it. Thanks for the quck help though...GOOD HELP SITE!
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Does the wireless card still show in the device manager?
  • Jay Glendenning
    Did you inadvertantly turn off the wireless card?
    What make/model is your laptop?
  • 404 Answers
looking at my collegues comments my I make a suggestion. I have an Mp600 and use Vista, I'm sure you are aware the Mp600 has compatibility issues with Vista. I downloaded all the relevant driver/s software to correct this and it works really well.
I hope this helps!
Paul 'W'
Onyer~EDson(:0)~[><U.K.
Posted on Jan 12, 2009
Canon MP620 cannot detect a memory card or USB flash drive for saving
Canon MP620 problem, not showing up at all - Windows 7 Help Forums
www.sevenforums.com > ... > Hardware & Devices
Apr 29, 2012 - He's got a Canon PIXMA MP620 and we're trying to get it to connect to his Windows 7 laptop. ... Basically, I started off with no trace of Canon in the laptop.Then, using the setup disc, I followed all the instructions up to actually connecting the printer to the laptop. Problem with wireless Canon MP620 printer connection Solved ...
Jan 26, 2013
Problems installing Canon MG6220 Wireless Printer in Win 7 x64 ...
Aug 28, 2012
Cannon PIXMA MX870
Feb 14, 2011
cannon mp620 printer
Mar 28, 2010
More results from www.sevenforums.com
Nov 04, 2015 | Canon PIXMA MP620 All-In-One InkJet...
I have cannon mp620 and have lost the disc and i need to set the printer up on my laptop what do i do
If you use Vista or Win 7 easiest way to connect wireless is:Go to "Network" find your printer in network area and press right button on it.Than press install. Should work (i have different language of my windows)
Oct 07, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I have a Pixma MP620 connected to Win7, but have wireless access and also use MacBook. Cannot print wirelessly to printer from Mac..........have a solution?
Make sure you have the drivers installed - while there are possibly compatible drivers that came with your MacBook, it may not work properly out of the box.
Download them from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp620#DriversAndSoftware. Make sure you choose "MP Drivers for Network". Do not install yet, but open the package file.
The next step requires a USB cable. You need to connect the MacBook to the printer and only then start to install the drivers by clicking the Setup icon.
You should do the 'Easy Install', if you get asked for it. When the installer asks to restart the machine, do so.
Once the machine restarts, you'll get a window for the 'Canon IJ Network Tool'. Click for 'Lan Connection', and then OK.
You'll want to click the 'Register Printer' button next. You may get a 'Cancel Setup' screen, just cancel that out.
The next part requires waiting. After a bit - really, it was different for all three computers, so I can't say how long - you'll get an 'Add Printer' screen. Choose 'Canon MP620 series', and click add.
On the Canon iJ Network Scanner Selector screen, set the pulldown for "Canon MP620 series Network', and then click the MAC Address (there should be only one) and cick 'Apply'. Make sure the check mark is displayed, then click exit.
That should register your laptop as allowed with your printer. Turn off the printer, disconnect the USB cable, turn the printer back on and you should be able to use it.
Apr 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
When I try to install canon mp620 on new computer
You may find some help at this link. It contains some very good guidance on setting up the MP620 on a wireless network.
May 21, 2010 | Canon PIXMA MP620 All-In-One InkJet...
How do I set up to print wirelessly with a Canon MP 620 Printer?
Hi
Thank you for your query
To share your printer you will need to do the following
1) On your desktop Click on Start>Control Panel>Printers and faxes
2) Right click on the printer in question and click on sharing
3) Put a dot in 'share this printer' and give it a name
This has now made your printer a shared one on the network
On your Laptops click on Start>Control Panel>Printers and faxes
2) Click on Add printer
3) On the resulting screen put a dot in the option 'A network printer, or printer attached to another computer'
4) Then follow through and the printer you named on your network
This will add the printer to your laptop and will allow you to print
Do the same for the other laptop
I hope this has been useful
Mar 12, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Printer not detected with Wrt54g2
Fixed it. I saw another post by someone, who had detailed step-by-step the setup proceedure with regrds to wireless. First, make sure printer is connected via USB to PC and everything works.
Next on printer, select settings, then device settings and Reset all network settings.
Next, run the CD-rom, select region, and then select Easy install when main menu appears.
Nest select only the most essential drivers, MP drivers and the Canon IJ Network tool. Select & reinstall the MP driver (main driver) and Canon IJ network solution tool.
Once they are installed. Run the Network IJ tool program, follow the setup to activate wireless.
This is how my MP620 finally worked.
Hope this makes sense.
Jan 04, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I'm trying to connect to my Canon MP620, wirelessly. All my other computers have been hooked up, catch is I had the disc. Windows automatically installed everything when I hooked it up with the USB cord...
If I understand you correctly, you have lost the software?
I'd recommend getting the software for MP620 from Canon. Select the operating system in the drop down box to the right of the text "Please select your operating system to view available drivers and software" on the page to reveal the software downloads relevant for your operating system.
Then run the network install using the downloaded and installed software on one of the computers. You have to connect the printer using the USB cable once to setup network access to the printer. After that, all computers should be able to see the printer through the network. The software should be installed on all computers that should use the printer.
I have set up wireless connection to the very similar Canon MP600R before, with success.
Aug 13, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Cannot install Canon Pixma MP620 drivers
printer propperties/connections/add...
add a new Canon BJNP port
this solver the problem for me
Nov 18, 2008 | Office Equipment & Supplies
Canon PIXMA MP600 all-In-One InkJet Printer Logo
160 people viewed this question
old marine
old marine
