Question about Bosch Water Heaters
I have a Bosch water wizard 10p system and when in use, the temp fluctuates hot to cold.
When having a shower, the gas burners goes out and the water goes cold, this is while still having the hot tap on! Thanks in advance
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
the problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
Posted on Dec 30, 2008
  • 82 Answers
SOURCE: Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Posted on Sep 04, 2009
co7196
  • 3433 Answers
SOURCE: water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Posted on Sep 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: I don't know how to restart my old bosch water
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Posted on Oct 06, 2009
  • 35 Answers
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Posted on Feb 19, 2010
Hi I have a Bosch water wizard 10p & although i have the heat turned up to the highest it is still not hot enough! I was wondering if there was another way of increasing the water temp?
Open following link for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Typical Bosch 10P manual shows temperature control illustration on Pg4, and includes low water temperatures on troubleshoot on Pg6
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
Water flow rate too high, low gas pressure, faulty thermostat.
Two other things might be causing problem
Crossover:
http://waterheatertimer.org/Crossover.html
Lime build-up
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Jun 15, 2011 | Bosch & Tankless LP Hot Water Heater
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Water heats, then turns cold
These units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 29, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
Bosch 2400E-NG output temp fluctuates
This is a great heater. It is however crucial that it be installed to every detail of the manual. If there is trouble send pictures to Bosch tankless you can call 1-800-283-3787 ask for Bosch Tech support or go to boschhotwater.com click find a contractor and call the closest Bosch Service Provider most will travel.
Mar 04, 2010 | Bosch AquaStar 2400ES-NG
Water wizard 10P pilot light keeps going out
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Bosch water heater
I'd initially check for a cross connection (cold water leaking into hot water system). This can be done by shutting off the cold water feed to the tankless unit, then opening up hot water fixtures around the home. You should see the water come to a complete stop; if you see a steady stream of water, then you have a cross connection. The most common place for a cross connection is at single handled showers. The valve cartridge starts to fail over time.
Jul 09, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
78 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
