Question about Canon imageRUNNER 2010F Copier
IR2010F check printer cover error - Canon imageRUNNER 2010F Copier
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Message says COVER OPEN CLOSE COVER but the cover is closed
The problem could be due to the printer cover sensor getting stuck or the cartridges in the carrier. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for errors.
8. If no error appearsl, open the printer cover and reinsert the other cartridge. Check for errors.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 11, 2011 | Lexmark X125 All-In-One InkJet Printer
Hello my lexmark printer model #5270 says Cartridge error #1203 I use black-32 color-33
The 1203 error indicates a short in one of the cartridges. Follow the steps below to fix the problem:
  1. Open the printer cover and remove both cartridges from the carrier
  2. Close the cover
  3. Unplug and re-plug the printer into the power source to reset it
  4. When the printer turns on, re-insert one cartridge first. Close the cover and check for errors
  5. Then re-insert the other cartridge. Close the cover and check for errors.
  6. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the new one is faulty.
Jul 12, 2011 | Lexmark X5270 All-In-One InkJet Printer
Error 1109
The error could be due to a cartridge problem. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
Jul 06, 2011 | Lexmark P6350 All-In-One InkJet Printer
Its a lexmark x1270 scanner n printer. it would not print since the new cartridge has been put in it says that the cover is open though its not and the support info i got i did everything the manual said...
It could either be the cartridges in the carrier or the sensor for the printer cover has gotten stuck. Please follow the steps below to determine and fix the issue:
  1. Open the printer cover.
  2. Remove the cartridges from the carrier.
  3. Close the cover.
  4. Unplug and re-plug the printer into the power source to reset it.
  5. When the printer turns on, re-insert one cartridge first. Close the cover.
  6. Check for any error.
  7. If none, re-insert the other cartridge. Close the cover.
  8. Check for any error.
  9. Replace whichever cartridge is causing the error to appear.
  10. If no error, try to print again.
Jun 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Error #1203 x7350
The 1203 error on your printer indicates either a communication failure between one of the cartridges and the printer or a short in one of your cartridges. Please follow the steps below to fix the problem:
  1. Open the printer cover and remove both cartridges.
  2. Close the cover.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, re-insert one cartridge first. Close the cover and check for any errors.
  5. If none, re-insert the other cartridge. Close the cover and check for any errors.
  6. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
Try to print again.
Jun 22, 2011 | Lexmark X7350 All-In-One InkJet Printer
I have canon IR2010F copier with ADF and automatic feeder slips while taking the document in the feeder and makes tic tic tic tic noise while taking in the paper in the feeder, When we provide hand...
there are two locking handles for the adf on either side of the cover of adf i am sure one of them is broken or disfigured that why when u press it the adf works.i dont think this spare part is available u have to use ur own creative skills to make it through melting plastic to make a hook for that side
Jun 05, 2011 | Canon imageRUNNER 2010F Copier
Printer wont print showing C 5 E on display
EC5 error code indicates a short has been detected in one of your cartridges. Try to remove both your cartridges from the printer. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any error. If none, open the cover and reinsert the other cartridge. Close the cover and check for any error. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
May 04, 2011 | Lexmark X2670 All-In-One Printer
Receiving cartridge error and consult user guide
Remove both cartridges from your printer. Close the cover. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover. Check for any error. If none, open the cover and reinsert the other cartridge. Check for any error. Replace whichever cartridge is causing the error to display. Or you could try to insert a different known good cartridge to determine if the other is faulty.
Apr 25, 2011 | Lexmark X4650 InkJet Printer
Close printer cover error when cover is closed
The cover sensor might have dislodged or not in its proper position. You could try to reset your printer to determine if there's a hardware fault. Remove the cartridges from your printer. Close the cover. Unplug and replug your printer into the power source. When the printer turns on completely, reinsert your cartridges. Check if error appears again. (Error: 'Cover open, please close the cover')
Feb 17, 2011 | Lexmark X2250 All-In-One InkJet Printer
Canon imageRUNNER 2010F Copier Logo
old marine
old marine
