Question about ASUS P4S333VM (AP4SRRVM) Motherboard
No matching of cpu clock and system clock frequency
Good day to all,
Motherboard model p4s333-vm and using pentium 4 1.7ghz and how am i set the bios setting when i set the setting to setup default.Pls adv.....
hughv
  • 196 Answers
SOURCE: Raid controller disabled to P5RD1-VM
The manual is here: http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf (very slow download). Look under Advanced/Southbridge/SATA
Posted on Sep 29, 2007
apple_rom
  • 40 Answers
SOURCE: MANUAL DE TARJETA MADRE
Manual for P4S333-VM
Posted on Nov 30, 2007
map9966
  • 2351 Answers
SOURCE: asus p5rd1-vm motherboard problem of graphics card
Hi shuter. Your Asus P5RD1-VM has an integrated video adapter ATI® Radeon 9600 GPU. You need to enter your bios & change the video start up order. Pg.2-22 in your manual.
Configuration options: [IGD] [PEG/IGD] [PCI/IGD]
Boot Graphics Adapter Priority [PEG/IGD]
Save & exit. Check system at boot up for correct memory count.
Thanks for using FixYa & if you need more help just re-post here. Have a good one!
please vote...
Posted on Feb 29, 2008
  • 47 Answers
SOURCE: intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Posted on Mar 21, 2008
shaky120
  • 310 Answers
SOURCE: DDR
Hey, checked up on the motherboard and it does work with pc3200 or 400mhz...
All the best
John
Posted on Jul 26, 2008
I want to install asus p4bg-vm grapics driver.
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jul 11, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I cant find motherboard model in my pc
Google for a program called Speccy - run that and you will get all your details.
Nov 24, 2010 | Intel ASUS P4S333-VM Socket 478 Pentium 4...
Alwyas get to bios cpu freq and hang
try clearing the bios and replace the bios battery.
Check the processors correct frequency and set it in the bios and save settings this should fix the problem.
Also check if your cooling fan on the processor is tightly fixed onto the cpu and motherboard
Dec 01, 2009 | ASUS P4S333-VM Motherboard
I have asus K8V-vm and i installed vista home premium which is working very well but when i try to install any kind of games or any software it do not support it.What should i do!
switch to xp pro sp2..
i guess ur using ram over 1gb..(though it may support upto 2gb ddr1 400/pc3200 fsb probably)!!
replace it with a standby n check..it may b a faulty ram..
make sure ur system clock speed is matching..
if ur using more than 1 ram, both must b of the same frequency..(eg 400fsb+400fsb / pc3200+pc3200 [correct]; 400fsb+333fsb [wrong])..
check if ur hdd is working fine and without any humming or oscillating noise..
also go for a bios update frm: http://support.asus.com/download/download_item.aspx?product=1&model=K8V-VM%20Ultra ....
..if ur not professional, do contact ur system admin/vendor....
Oct 26, 2009 | ASUS K8V-VM Motherboard
I have been having some boot problems into windows with my p4s800 mx motherboard. I have purchased it with a 3,0 ghz cpu and put it together yesterday, after which I tried to boot it. It works on lets say...
The BIOS utility probably has a setting for the BIOS to automatically detect and maintain your CPU's clock speed. Make sure that is ON or ENABLED. Another probable reason for the failure may be your RAM settings. Again, use the automatic detection of your memory's speed and latency settings.
One last probable reason may that you may be using different kinds of memory SIMMS or DIMMS. Some boards are very finicky and will not work efficiently with different types, if at all. Others will simply not work.
Aug 16, 2009 | Computers & Internet
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Intel cpu ucode loading eroor
Mar 21, 2008 | ASUS P5PE-VM Motherboard
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Feb 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Computers & Internet Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
