Question about Canonical Ltd. Ubuntu
SMTP server is unknown as it may be incorrectly configured
    Sergeant:
  • 283 Answers
This is for sending email. Check what your email provider says your setting should be and check what you have set in the SMTP section of your email client on your computer.
Posted on Oct 29, 2013
How to configure gmail SMTP setting for outgoing server?
Process to configure gmail SMTP setting for outgoing server
Gmail provides email services to user.It is used for sending and receiving mail.It is freely used by users.It is developed by Google.If you create an account an G mail then you can directly open your Google account there is o need to create another account. It provides unlimited space to user. For some Business application Gmail is used as paid .Gmail is used as open source.
When you use Gmail then you need to check that your server is connected to Gmail or not.You should know that Gmail SMTP server is used for sending email from your Gmail account. SMTP is Simple Mail Transfer Protocol ,it is used for every email account but it is not same for all the accounts.so for Gmail Account you need to configure Gmail SMTP settings then you need to follow these steps:
First you need to go in the Email client software then you have to go in the outgoing mail
first you need to check that your Gmail SMTP server Address that should be SMTP.gmail.com.
Then you have to enter your Gmail SMTP user name ,your SMTP user name should be same as your Gmail address.
Then You have to enter SMTP Gmail password,it will be your Gmail password.
Now you have to enter Gmail SMTP port number for TLS and secure socket layer connection.
Then you have to select "Use SMTP authentication".
Then you have to click on YES if if you see that Gmail SMTP TLS/SSL required.
Then your SMTP server will be set to your Gmail client.
You can easily configure your SMTP Gmail Setting with the use of above steps but if still you are not able to configure your SMTP settings then you can contact Gmail Technical Support for any query .They will provide you best solution.
GET INSTANT SUPPORT FOR YOUR GMAIL ISSUES NOW
Jun 15, 2017 | Computers & Internet
Server details are not incorrect but being told they are
Hi here are the server details for yahoo. Please check them against your current configuration and reply back with OS, Mail client and your error details if this configuration doesnt work.
  • Incoming server - imap.mail.yahoo.com
  • Outgoing Server - smtp.mail.yahoo.com
  • Incoming port - 993 (SSL enabled)
  • Outgoing port - 465 (Again SSL or TLS enabled)
  • Username - full email address@yahoo.com
  • Password - your password.
Thank you.
Mar 03, 2011 | Yahoo Mail
My blackberry 8310 show jvm error 102
Cause 1:- There is no MX record for the Internet domain associated with the BlackBerry Enterprise Server user. Error 1 appears.
Resolution:- Create an MX record for the Internet domain. Make sure the computer running the BlackBerry Manager is pointing to the correct DNS server.
Cause 2 :- Incorrect DNS settings
Resolution :- Ensure the computer running the BlackBerry Manager is configured with the correct DNS settings.
Cause 3 :- BlackBerry Manager is not allowed to make a direct SMTP connection to that mail server.
Resolution :- Configure the mail server referred in the MX record to allow the direct SMTP connection from the BlackBerry Manager.
Thanks for using fixya.
Oct 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Outlook express
0x800CCC78 SMTP_REJECTED_SENDER Unknown sender. This is caused by having the incorrect e-mail address in the Reply-To field.
You may have to authenticate in outlook express by putting in the SMTP server name of your internet provider instead of yahoo
for example
Incoming = smtp.mail.yahoo.com
Outgoing = smtp.yourISPservername
Some isp's will not let you send out with a different smtp server than theirs.
It's why you can receive but not send.
Sep 15, 2009 | E-Machines eMachines Desktop PC
Brother MFC-7840W won't connect to gmail. DNS resolution error.
I'm pretty sure that the problem (though the machine indicating otherwise) is that gmail requires SSL, and the Scan to Email (server) doesn't support SSL. If this is the problem, you can easily check it out by trying to use some other mail, with another SMTP server, which doesn't require SSL.
Jun 13, 2009 | Brother MFC 6490CW InkJet Printer
No email can not be sent or compuse or reply
After deleting and recreating an account in Mail, you might not be able to send emails even if you can receive them. When you try to send a message, this alert may appear:
"Cannot send message using the server smtp.xxxxx.com"
This happens if the Simple Mail Transport Protocol (SMTP) server, used for outgoing messages, was incorrectly entered with the first account even if it was correctly entered for the replacement account.
Products Affected Mail
Resolution You should first verify that the network connection you're using is the correct one for the ISP that you want mail to communicate with.
  1. Open Mail.
  2. From the Mail menu, choose Preferences
  3. Click Accounts.
  4. On the Outgoing Mail Server (SMTP) pop-up menu, choose Edit Server List.
  5. Delete all entries for the SMTP server that is mentioned in the error, and click Done.
  6. Configure the current SMTP server by clicking Server Setting.
    Note: If you need to use multiple SMTP servers for multiple Mail accounts, see this document.
  7. Send a test message to your email address.
Jun 02, 2009 | Yahoo Mail
Cherrytree5@bigpond.com--- access to email obstructed.
Sorry you are having this problem,
Sounds to me like your eMail client configuration is incorrect...
Is this a new problem where you were able to send an receive mail no problem before and now this ?
I suspect it is a new set-up.
It looks like you entered your eMail address where the software was asking for the address of the SMTP mail server...
Port 465 is for a secure SMTP Server.
Normally, the SMTP server port is 25 or 26. Have you modified your eMail settings lately ? Or maybe it works well from home but not when you are on another network....
Bigpond has implemented some security on their network, see here:
http://bigpond.custhelp.com/cgi-bin/bigpond.cfg/php/enduser/std_adp.php?p_faqid=5562
So, when you are connected to the bigpond network, you must use their SMTP server:
mail.bigpond.com
Otherwise, it will reject the connection.
When you are away from the bigpond network, you might have to ask your host or whoever, who provides the highspeed internet access ? and then google for their smtp server,
ex: securenet.net smtp server earthlink smtp server
you will quickly and easily find this server and all you have to do is enter it temporarily into your SMTP server field in your eMail client settings making sure to set it back to bigpond once you are back home..
THis should get you back on your way again.
Mar 27, 2009 | Apple iMac G4 20" Mac Desktop
Can't send Tesco email through Sky Broadband
Hi there, it appears that the settings in your tesco account are incorrect, they shoud be set up for the tesco server , please see
http://www.tesco.net/help_section/email.htm hope that this helps
Martin
Jan 23, 2009 | Computers & Internet
I can not send emails. I am being told that I need 530 authentication is required. What is that.
error 530 has something to do with incorrect logon details. pleas double-check your outlook configuration. like the smtp server, outgoing server, or incoming server. re-enter your account details like username and password then try again.
Jun 05, 2008 | Computers & Internet
Outlook Express - email
ur pop3 server may be nmma.sancharnet.in at port 110
ur smtp server may be nmra.sancharnet.in at port 25
try these...
Jan 23, 2008 | Computers & Internet
Canonical Ltd. Ubuntu Logo
66 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
