Question about Brother Office Equipment & Supplies
Brother Printer HL 2142- has paper jam - Brother Office Equipment & Supplies
  • 826 Answers
If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Dec 06, 2012
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Mar 18, 2009
mbase213
  • 728 Answers
SOURCE: PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
    Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Posted on Apr 04, 2009
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
SOURCE: paper jam on Brother HL-1270N
paper jammed in printer
Posted on Feb 08, 2011
dajots
  • 92 Answers
SOURCE: Brother printer HL-2142 has a paper jam and our
You can get the manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2040_all&dlid=&flang=English&type2=-1
let me know it this helps :)
Posted on Apr 07, 2011
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
I have a Brother HL-2142 Compact High quality mono laser printer and I am having trouble putting the new toner cartridge back in as it flashes error and the paper gets jammed. I dont know where the...
Open the front door and pull the whole toner and drum unit out of printer. The toner locking lever is usually on the left hand side as you see it and is usually blue in colour. It needs compressing and at the same time lift the front of the toner cartridge out of the drum unit. Your new cartridge will simply lock into place. When you install the complete unit and close the door, the new toner cartridge will reset your printers counter.
May 20, 2011 | Digital Products Brother HL-2040 Laser...
Brother printer HL-2142 has a paper jam and our manual has been misplaced. Help woud be appreciated very much. Thak you.
Apr 07, 2011 | Digital Products Brother HL-2040 Laser...
Our Brother printer HL-2142 has a paper jam and we cannot locate our manual. Can you help?
hi there!
for paper jam, dont simply pull the paper out of the printer, this will damage the feed mechanism of the printer. but if already did, just open up the cartridge door of the printer (also check on the duplexer at back if it has), check for paper tear, clean rollers if you can too. this is the manual for your printer aswell since you lost your copy:
http://www.brother.com.au/PDF/Clients/Printer/HL-2142_Brochure.pdf
Apr 07, 2011 | Brother Office Equipment & Supplies
How do I unjam paper in HL 2142
You open your printer (use your manual to correctly do this)
check all paper paths to see if any paper is stuck
Next take out the toner and drum and check again for any stray scraps of paper that may have been stuck there.
Also open the paper tray and look inside there to see if anything is stuck there.
If your printer has a single sheet tray check there too
If your printer has a back opening, check there too
I recomend that you also purchase "paper path cleaning sheets" to keep the unit clean and paper jam free (once a week if you print constantly and twice a month if a casual user)
NEVER NEVER NEVER get mad and RIP out stuck paper. Such an action will break internal mechanisms inside your laser printer.
Hope this helps Have a great day
Mar 06, 2010 | Brother HL-2040 Laser Printer
May 27, 2009 | Brother HL-2040 Laser Printer
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
