Question about Brother MFC 420CN All-In-One InkJet Printer
When i run a test pattern on my mfc 420 it will not print the yel
It will print all colors except yellow
    Problem Solver:
  • 14 Answers
Clean the yellow printer head with the self cleaning function. Try printing yellow from a computer, etc. Check ink level, make sure it is not telling you low ink.
Posted on Jan 13, 2009
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Brother MFC-240C PRINTER yellow will not print
Try cleaning the heads - either with the printers software / drivers, or manually with q-tip and alcohol.
Mar 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Yellow ink not printing after cleaning utilities run; others ok
Your print head is bad. Try cleaning it with a tissue. You may see if you can find a replacement for that printehead.
May 04, 2009 | Office Equipment & Supplies
Can not get yellow to prent out on the test sheet
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 11, 2009 | Brother MFC 420CN All-In-One InkJet...
Yellow is a greenish color
Try printing this test pattern. I got this from this other website. But as ridiculous as I may sound, did you put the yellow cartridge into the Cyan compartment? Because to produce green you need to combine yellow and cyan. This test pattern will tell you which colors are not working properly. Then we can trace which cartridge is the problem or not. Let me know the colors that come out.27dfd86.jpg
Jul 22, 2008 | Brother MFC-410CN All-In-One InkJet...
Print color not functioning correctly
Is there a printer calibration program on that printer?
You should run it an make sure the color distribution settings are correct.
Jun 14, 2008 | Brother MFC 4420C All-In-One InkJet...
I Have a Brother MFC-640CW all-in-one Inkjet Printer. I changed the ink cartridges and I can get them all working except the yellow, when I do a Test print all the other colors come out perfect except for...
press menu then start bk copy then fourtimes arrow-up quickly after another. machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-bk-copy).
Machine will do some refreshing of ink and some special cleaning.
When finished press 7-6-3 start-bk copy
machine will do a power purge.
leave maintenance mode by pressing 9-9.
do run a test print.
DO USE ORIGINAL BROTHER INK or skyhorse generic ink only due to the fact that other generic ink will defenetly do damage to the printer!
Apr 23, 2008 | Office Equipment & Supplies
Mag & Yel Ink don't work
replace ALL carts with new ones.
press menu then start bk-copy then fourtimes arrow up quickly one after another. machine turns to maintenance mode.
press 7 then 6 then 4 then start bk-copy.
machine will initiate the carts and refresh ink in tubes and ph and do some special power cleaning.
when finished press 7 then 6 then 3 then start bk copy.
machine will do a power cleaning.
when finished press 9 then 9 to leave maintenance mode.
run a test print.
If you cant see any yellow and/or magenta the ph is defective and needs replacing (this happens mostly because of generic ink which contains the wrong chemical mixture to keep the ph alive).
Mar 24, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
213 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
