Question about Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2...
How to configure nortel 2526t snmp - Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2...
2 Suggested Answers
  • 82 Answers
SOURCE: how to configure STACK IP on nortel 2526t IN USE
for the answer to the query log on to the web site http://nortel.com/
Posted on Feb 10, 2010
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
I have a nortel tasman 1004 with 1 t1 port licensed. I need to have it reconfigured to a new location with new ip address and updated software if possible... I have tried to program it myself and keep...
Here are some commands to configure your tasman router :
tasman> sh configuration runn Please wait... (up to a minute)
terminal exit terminal qos exit qos module t1 1 clock_source line alarms thresholds exit thresholds exit alarms linemode exit linemode exit t1 module t1 2 clock_source line alarms thresholds exit thresholds exit alarms linemode exit linemode exit t1 interface ethernet 0 ip address 66.201.12.x 255.255.255.0 <------- for example ip multicast ospfrip2 icmp exit icmp qos exit qos vrrp_mode 0 exit ethernet interface ethernet 0.1 ip address 62.18.3.0 255.255.255.0 <------ for example ip multicast ospfrip2 icmp exit icmp qos exit qos vrrp_mode 0 exit ethernet interface ethernet 1 icmp exit icmp qos exit qos exit ethernet interface bundle MFR1 link t1 1 link t1 2 encapsulation frelay fr intf_type dte frame_size 4470 mfr fragment_size 4000 mfr seg_threshold 3999 lmi ansi exit lmi pvc 500 shaping cir 3072000 bcmax 3072000 bcmin 65536 no policing ip address 15.10.16.86 255.255.255.252 <------ WAN IP address to ISPicmp exit icmp red exit red exit pvc exit fr icmp exit icmp qos exit qos exit bundle aaa radius exit radius exit aaa snmp system_id tasman1 enable_trap exit enable_trap exit snmp hostname tasman telnet_banner exit telnet_banner event exit event system logging syslog exit syslog exit logging ip load_balance per_flowroute 0.0.0.0 0.0.0.0 15.10.16. 85 1exit ipfirewall globalalgsexit algsmax-connection-limit self 2048exit firewall firewall internetexit firewallfirewall corppolicy 1024 out permitexit policyexit firewallpolicy community_list exit community_list tasman>
Or use the link below:http://www.ipbalance.com/vendor/tasman-networks/454-mlfr-boundle-serivce-configuration-for-tasman1004-router.html
Dec 04, 2011 | Nortel Networks SR1004 4P ACTIVE T1 ...
How can I activate PoE port on avaya2526T switch?
Try this: http://www.retrevo.com/support/Nortel-2526T-PWR-Switches-manual/id/8084dj990/t/2/
Jun 18, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
Switch not connect hyper terminal
If you are connecting to the switch using the console port using a console cable. Make sure your settings for hyper terminal are on COM1 and the baud rate is 9600.
If you are trying to telnet, you will need to assign an IP address to the VLAN in order to telnet into the switch and configure a password or it will not let you in.
Mar 04, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
How to config ip to nortel switch
on the Nortel Passport sw
vlan x
ip address x.x.x.x
ip address netmask x.x.x.x
on the interface
ip address x.x.x.x
on the Baystack
it smilar to the cisco sw
pls try and tell me
Dec 03, 2010 | Nortel 2526T-PWR Ethernet Routing Switch...
Confi stack on nortel switch 2526
Hi friend i want help can you give me the reply. i have 4 nortel 2550T-24 port switch but i don't know how to active stack config.
Sep 27, 2010 | Nortel 2526T-PWR Ethernet Routing Switch...
Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2... Logo
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
