Question about Whirlpool Refrigerators
Need controlboard 08032293 to refrigerator
If you nock on the controlboard the compressor start some thin wrong in the component on the board. what to do?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 07, 2012
  • Runo Blidstrand Dec 07, 2012
    ARZ 624/H or CB60PL E-2CP FAN
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Whirlpool Refrigerator neither cools nor freese
Have the model number? Can you feel the top of compressor to see if clicking or getting hot trying to start? 3_5_2013_2_17_27_pm.jpg
Sea Breeze
Nocking on refrigerator anywhere and starting is a loose or defective connection like a defective thermostat will cause these symptoms.
Mar 05, 2013 | Whirlpool Refrigerators
GE Adora model #DSS25KSRASS side-by-side - the refrigerator side is not staying cold and periodically quits working
This is a very common problem that comes with your model refrigerator. I need you to pull the refrigerator away from the wall, unplug power, remove the panel covering the compressor and feel the top of the compressor. Is the compressor too hot to keep your hand on the top? What I believe is happening is the control board or the start components are defective causing the refrigerator to cool off and on or periodically as you said. The solution may require a new control board=> WR55X10942 Main Control Board
and new compressor start components=> WR62X79 Run Capacitor
and the=> WR07X10057 Start Relay
Should you choose to repair your refrigerator I will happy to answer your questions. This model GE refrigerator has caused many complaints because of the expense and frequency of this type of repair. Many home owners are better off with a refrigerator that does not have a motherboard and uses simple defrost timers or defrost control boards. Here nis a link to a=> DSS25KSRASS Service Manual
GE ARTICA PROFILE TECHNICAL INFORMATION If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | Refrigerators
The unit compressor will not run, wondering if it's a component that supports the compressor or the compressor it'self. how do I tell? there is some clicking within a white component mounted on the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Refrigerators
Refrigerator stopped working nothing runs,all lights on, periodically a clicking sound
sounds to me like you have a bad relay on your main control board. It will be located on the back wall of the unit or down by the compressor on older models. The other possible clicking noise would be your starting components on the compressor. You will have to determine where the clicking is coming from and I would start by replacing either the board or the starting components. You could also do a visual inspection on the board for burn spots. Hope this helps. MJ
Jul 30, 2010 | LG LFX25960 Titanium Bottom Freezer French...
Refrigerator temperature control panel not lit. This happened last week but corrected itself....not sure how....but now display panel is off for good, it seems. Main Refrigerator lights are still working,...
Your Refrigerator Has a main controlboard located in the rear of the machine. This Controlboard sends power and reads the user information. if your user display (Temp Control panel) is not working it can only be 2 things The user display or the main controlboard.
As far a the refrigerator working without it, I would not trust it.
The clicking noise is a relay on the main control.
Usualy when I here this relay go on and off rapidly, there is a problem whith the main controlboard.
The big problem with this is why did the main control go out ? some other componet on the refrigerator could be the cause. A comon cause in the past has been the evaperator fan motor.
Jan 15, 2010 | Refrigerators
My GE Profile Artica refrigerator front panel stopped working. On lights on any option. THe refrigerator & freezer appear to be working fine. Model number is PSS25NGNA CC
the front panal is called the interface. this interface has a small controlboard in it that talks to the main controlboard. I would change the interface first but in small ocations the main board would need to be replaced also. the interface part number is
WR55X10390
Jan 07, 2010 | Refrigerators
Condensor fan motor starts, evap motor tries to start, compressor tries to start but then the relays on the mother board begin to click on-off-on. Should the start relay be normally closed when the...
1. GE is replacing many defective boards free of charge. Check with them to see if you are qualified.
2.The start relay should be closed when refrigerator is de-energized.
3. Still a possible bad compressor or compressor start components. Test performed by service tech on compressor is usually done with a starting test cord. Would answer many questions quickly.
Oct 30, 2009 | GE Refrigerators
Refrigerator not cooling.
If the refrigerator isn't cool, check to see if the light comes on when you open the door. Next check to see if the thermostat is set properly. If both of these are OK, then check to see if the compressor is running. See if the compressor motor is running. The compressor is in a case with no visible moving parts. It is usually located at the back of the refrigerator near the bottom. If it’s humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components.
Refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8’s of a turn. If the compressor starts, replace the defrost timer. For further help, you’ll want to call a professional appliance repair technician.
Sometimes you can hear a click-buzz-click sound coming from the compressor. This is the relay/overload at work. If you hear this, power is getting to the compressor. If you do, something is wrong with either the compressor or the compressor starting components. If you have a newer model with solid-state starting components, you may not hear anything at all. If there is power to the starting components, you may be able to test each part and replace any bad parts. There is also a 3-in-1 unit that may work on your model which replaces all the components in one unit. If the compressor still won’t start, you have a bad compressor and need to replace it. If it does start, wire the 3-in-1 part in permanently. Make sure the one you buy is rated for the horsepower of your appliance.
If you don’t hear anything, you can take the cover off the side of the compressor and test for voltage at the two leads. If no voltage is present, it’s time to check the cold control. To test if the cold control is bad, you can temporarily jump the two wires at the cold control. If you get power to the compressor after doing so, the cold control needs to be replaced.
Aug 13, 2009 | General Electric GTR16BBSR Top Freezer...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
