Question about Ricoh Aficio AP410N Laser Printer
The printer types this code on the screen SC 868 power off on and the light is red so it does not work
2 Suggested Answers
  • 172 Answers
SOURCE: Hi, I have a Ricoh
Browse the below link & go to troubshooting section.
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001030/0001030158/VG1487201/G1487201.pdf
I hope you will find your solution.
Thanks
Posted on Mar 14, 2011
Tc-p60st50
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 25, 2016 | Televison & Video
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Nov 08, 2014 | Office Equipment & Supplies
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
Oct 26, 2010 | Ricoh Aficio 1035 Copier
FUNTIONAL ERROR SC:868
HI
SC 868 - An error occured with the SD card.
Solutions -- SD card not inserted correctly,or is defective.
controller board defective.
Hope this helps you.
Jun 29, 2009 | Ricoh Office Equipment & Supplies
Error sc 490
try to rest the code by hitting the Yellow clear botton, then the numbers 1-0-7 then press and hold the red clear/stop botton for three seconds. The screen will change and then turn the copier off. this should reset the code.. That is if there was a power problem. Try it and see what Happens..
Feb 12, 2008 | Ricoh Aficio 450 Copier
Lanier LD032c Photocopier The red spanner light is on and the screen is stuck on 'downloading, please wait'. If you could suggest a way to fix this as we have turned the machiene of to reset and it still...
Try a software reset which involes holding down the * and # (next to the 0) buttons for about 10 seconds until you hear a beap. You should then see "Now loading. Plese wait" and it should start up normally.
Its possible the machine has just locked up. If the above procudure dosen't work power off at the power piont and leave off overnight.
Please advise if any SC codes are present with the spanner for further help.
Feb 05, 2008 | Lanier 1205 Copier
Ricoh Aficio AP410N Laser Printer Logo
192 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
