Monitor fault i have ibm color monitor. when i connect it to pc the message shown is: no connection check signal cable. pl. help me. pl. tell me any reasonable repairng centre/ shop in mumbai. thank u.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    It may be the PC you are connecting it to. The video card could be bad .. Does the PC work with a different monitor?
Your monitor data cabel can be bad check this.if it is ok. then problem in motherboard.
Posted on Jan 30, 2009
    Problem Solver:
  • 82 Answers
Try removing the RAM from the motherboard & fix it again...... if this will help you u might not need to go service center.......or check the dispaly cable which is connected to your CPU........hope thjis will help u...............Sameerrayan
Posted on Jan 14, 2009
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously. in...
It usually depends on the monitor type and/or whether the monitor power cable is connected directly to the wall-socket or to the PC casing first. Both might explain the different behaviour. If they're all connected the same way, it's just the type of monitor that doesn't go into 'standby' mode automatically when there is no signal. You could post the exact make and model monitor and/or contact their customer support, but it's more likely not a configurable option ...
Oct 17, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
Power light is on &no signal message is shown after connecting cable video is not available
Did you tried to connect the monitor to another PC for a test?It sounds most like a PC graphics card problem or is set a very high resolution that is not supported by the monitor.
Sep 24, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
How do i get rid of "CHECK SIGNAL CABLE" on my 17" flatron wide monitor?
"Check Signal Cable" message is shown on the monitor only when their is disconnection between PC & monitor or if the cable is faulty. You can get rid of the message, which is built-in the monitor. Try changing the faulty cable.
sonsunny
Jun 28, 2011 | Dell Dimension 3000 PC Desktop
No display with vga or dvi, but "no signal" without cable
Stick with the VGA cable. You have tried several PC's but are you also using the same cable? Bad cable perhaps? How about software conflicts? Really should not be an issue as most are plug and play.
Try connecting a laptop to it with the VGA cable. Use the Function "FN" key with the F series on top row...the one with the LCD or monitor icon on it, usually F5, F7 or F8. This tells the laptop that you have connected an additional external monitor to it. If that fails, something is faulty with the monitor and there is not much I can do to help. Sorry...but let me know about the laptop connection.
Jun 30, 2010 | Princeton Digital VL2018W Monitor
I show on monitor "no signal" Check Signal Cable
Check that the "data" cable between your computer and your monitor is tightly connected at each end.
Connect the VGA-output port from a laptop computer to the monitor, to see if the monitor works when connected to a different computer.
Connect a different monitor to the VGA-output port on your computer, to see if that monitor works.
Failing all the above, the video-card on your computer is the problem, and needs to be replaced.
Nov 05, 2009 | E-Machines (T3104) PC Desktop
IBM Flatscreen saids No Connection....Check Signal Cable
no it is not the fuse ..but the fault is with the power supply.
Aug 23, 2009 | Computers & Internet
I have ibm monitor, when i connect it to my pc. it shows the message no connection check signal cable. pl. help
Either the video card is not working inside the computer, you're using the wrong video card, or its resolution and/or refresh rate is set higher than the monitor can handle.
Jan 05, 2009 | Computers & Internet
Delay time when My monitor is turned on...
It seems me that ur monitor is too old thats why..
Dec 01, 2008 | Computers & Internet
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
