Buffalo WBR2-G54S router setting up a Virtual Server
Have a IP camera that requires a Virtual Server
  • 7,627 Answers
2 Suggested Answers
  • 8 Answers
SOURCE: Buffalo Technology AirStation WBR2-G54S Router Installation
type in 192.168.11.1 in your web browser and you will have to login using user name root and password that you had setup during installation. After loggin in you will get the router configuration page.
Posted on Jun 07, 2009
How to configure
The WHR-G54S has a default LAN IP address of 192.168.11.1
and Subnet Mask of 255.255.255.0.
Make sure your computer has an IP address in this range 192.168.11. x
Open your browser
type http://192.168.11.1
you will enter the web interface of the router
root is the username and no password is needed.
Configure your router.
http://cdn.cloudfiles.mosso.com/c85091/WHR-G54S-Manual-v1.9-web.pdf
Mar 22, 2014 | Buffalo Technology WHR-G54S Wireless...
Error Message "The server 192.168.11.1
The default name suggestions that no additional configurations have been done on the device out of the box. The default login should be "root" with no password. If this fails, see the source for information on resetting the device to factory defaults.
source: http://portforward.com/english/routers/port_forwarding/Buffalo/WHR-G125/Echolink.htm
Jun 26, 2011 | Buffalo Technology AirStation WBR2-G54S...
Have forgotten the password to log in on my buffalo WHR-G125 router. How can I find what it is or reset it to default?
Reset to factory settings is usually a small button on the back of the unit. It may be a very small hole which you will have to insert a paper clip into to press.
Mar 15, 2011 | Buffalo Technology AirStation WBR2-G54S...
I have forgotten my password. How do I reset the router to defaults if I can't log in? I have a Buffalo wbr2 g54s
You will need to get a ping or paperclip, something that is small. On the back of the router will be a little whole and inside that whole will be a reset button. Hold that button in with the paperclip or pin until the lights on the front of the router flash. Once that is done it has been reset. Then the usual password is:
Account:admin
Password: password
Feb 28, 2011 | Buffalo Technology AirStation WBR2-G54S...
Trying to confirm my password for my buffalo WBR-G54 router in order to wireless connect another pc
If you haven't changed it then the defaults are:
Username: root
Password: (blank - the password is blank)
Info from the manual here:
http://site2.buffalotech.com/downloads/WBRG54Manual.pdf
Sep 09, 2009 | Buffalo Technology AirStation WBR2-G54S...
I want setup drivers for this product
There are no drivers or setup CD for the router. Here is a link to the users manual:
http://homepage.eircom.net/~buffalo12/WBR-G54_Manual.pdf
Mar 14, 2009 | Buffalo Technology AirStation WBR2-G54S...
Cannot open web page through router
Try opening network connections TCP/IPv4 on your pc and add ip address manualy to be in the same number match the same as your router ie default gateway and preferred DNS Server eg 192.168.1.1 or 10.1.1.1 depending on what default the router is set on the ip address should be the same apart from the last no. eg 192.168.1.8 or 10.1.1.8 subnet mask will default to the right setting if you push the tab key after entering the ip address
Hope this helps
Feb 27, 2009 | Buffalo Technology WHR-G54S Wireless...
Can't configure router for Domain name and DNS
dns= domain naming service or something alike...
you don't have normally to anything to your router other than allowing incoming traffic to port 80...once you do that, you should be all set..frrom your computer at home if you type your domain name, your pc actually goes to the internet clowd and accesses you new domain name based on the info gathered by dyndns...then comes back to the ip that your ISP assigned you and hits your webserver...
A couple things to consider;
keep an eye on the ip assigned to you by the ISP..if it changes by DHCP your webserver won't be seen by the outside..
on your side of the home network, assign a static ip address, don't use dhcp as well to avoid the same problem on the pc that you have the webserver. your router should allow you to allow traffic on port 80 to your webserver computer, which has the static IP...
if it does not, buy another one
Feb 07, 2009 | Buffalo Technology AirStation WBR2-G54S...
Connection to intenet new router
hi
to login to the router your checkk the default gateway address and type the same in to the browser and launch in to the router to do check the configuration...
mac - check in network coonections
pc - ipconfig
cheers !!!
Feb 13, 2008 | Buffalo Technology AirStation WBR2-G54S...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
