Question about LG WFT1071TP Top Load Washer
LG wt-h800 with an iE error - LG WFT1071TP Top Load Washer
2 Suggested Answers
  • 6277 Answers
SOURCE: LG WT-H800 Fuzzy Logic. Everytimes
For LG's 'PE' stands for '(water) Pressure Error'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Aug 30, 2011
Model Wt-h550. What does fault code AE indicate?
This error AE normally indcates a water leak,try tilting machine backwards or forwards 2 see if any water comes out from base of machine
Dec 22, 2015 | LG Washing Machines
Have a LG WT-H800 washing machine that makes a terrible grinding sound. I removed the very bottom nut and pulled the cover off. I found the plastic piece attached was all chewed out and broken. Now only if...
Go online to appliancepros.com and put in the model number and your washer will come up with photos of all the parts and you can match to the one that you need.
Apr 20, 2014 | Washing Machines
LG TURBO DRUM DD WT-R854
my LG Turbodrum DD 8.5 KG WT-R852 have an Error Message (A). What can i do
Oct 25, 2012 | LG Washing Machines
LG WT-H800 Fuzzy Logic. Everytimes I turn on the power. "PE" error code will appear. What does it mean & how could I solve the problem.
John C
Aug 30, 2011 | LG WFT1071TP Top Load Washer
We are getting an LE error on a LG WT R852 washing machine
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Aug 13, 2011 | Washing Machines
LG WFT1071TP Top Load Washer Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
