Question about Buffalo Technology AirStation WBR2-G54S (747464109220) Router
How to setup a virtual server on router - Buffalo Technology AirStation WBR2-G54S (747464109220) Router
  • 826 Answers
Virtual Server, also referred to as Port forwarding or port mapping can be setup with the router.
The setup of the virtual server depends on what you want to setup.
Virtual server is used to allow computers not on your internal network or computers on the internet to access a resource or service on the internal network.
For example:
Say you have an FTP on your internal network that you want people on the internet to access. To set that up go to the virtual server screen on the router and specify the IP address of the computer on the internal network that has the FTP server on it. The private port that you want to specify would be 21 because port 21 is FTP. The public port could be any number you want it to be, for ease of explanation lets just say it is also 21, that is the port the public would use to access the machine. For a computer on the internet to access the FTP server on the internal machine they would open up a web browser and type FTP://(WAN IP ADDRESS, found on main status page of router screen):21.
A better example would be FTP://1.1.1.1:21
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Dec 06, 2012
Port forwarding
In your router's setup menus, click Advanced Setup, then click NAT, then click Virtual Servers.
That's the port-forwarding configuration page for Primatel routers.
Feb 10, 2014 | Computers & Internet
Why in weapons of war cannot connect to the server
You may have use an open port or sometimes called virtual server, depending on your wireless router. Go to portforward dot com and use their free setup instructions.
Apr 01, 2013 | Computers & Internet
DNS server not responding on WRT54GL Linksys router
You are looking for DHCP server. It provides the IPs addresses for devices to connect. DNS resolves the IP into a name. Not really required unless you are setting up a virtual server, or the special setup.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
  1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
  2. Click on Login, Advanced Setup, NAT, Virtual Server.
  3. Enter the port details and enable it as follows:
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
  2. Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y
* The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Jan 05, 2011 | SMC TigerSwitch SMC8612T
How do i change my NAT to open on my tenda W307R
Im only a couple years late, but i spent an hour on my computer last night to figure it out. Enter your ip adress in the top bar thingy. Enter your username and password. You should now see something with the selections "System Status, Setup Wizard,etc" on the side. Click on Virtual Server. Under Virtual server, you should see something called "DMZ Settings". In there, enter the ip adress of the computer/console you want to open the NAT. Click enable, the hit apply. Your Done.
Nov 26, 2010 | Port Designs Tenda W307R-103421 Router
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows. 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Virtual Server. 3. Enter the port details and enable it as follows: Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Buffalo Technology AirStation WBR2-G54S (747464109220) Router Logo
507 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
