Question about Mitsubishi WS-65809 65" Rear Projection Television
TV has a beige tinted, rectangle, see through box pop up randomly for a second then goes away, it covers most of the screen any sugestions?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Look first in the captions area for TEXT---if its on there will be a blank box in the middle of the screen but usually it will be black--look to see if TEXT is engaged.
Posted on Dec 06, 2012
  • Kim Blaty Dec 06, 2012
    Thank you very much! My TV is all fixed!
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: wt46807 tv projection black box
This can come from either the set or a box connected to it for signal.
Under closed captions either the set or the box is set to TEXT--never used but many sets have this feature---check the menu in the set first and then if using a box for signal check there.
One of the two is causing this.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions, comment here and I will assist you.
REGARDS, SD TECH
Posted on Sep 13, 2010
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi 55 in. WS-55315
Go into the menu and see if your closed captions are on and set to "TEXT". Setting the closed captions to "OFF" should solve your problem.
Posted on Jul 26, 2007
  • 5 Answers
SOURCE: When I turn on tv, there is a big black rectangle
turn off close caption
Posted on Dec 01, 2009
TV is about 1 year old. Started yesterday having a black rectangle in the middle of the screen. Can press any button and it goes away but come's back in just a few seconds. Tv is a Element ELCHS321
most times a black rectangle pops up when closed captioning is on. sometimes there will be gibberish in it sometimes not. See if you have button on remote labeled "CC" . Also if you have a cable or sat box make sure closed captioning is switched off there too.
Jan 21, 2010 | Televison & Video
I have a remote control TV. It is an old unit.
Hold in vol.up and vol. down at the same time. OR Channel up and channel down at the same time for 5 seconds. If you still have the same problem.Go into the menu and goto cc or close caption or text and turn it off. One of them should do it.
Sep 25, 2009 | RCA Televison & Video
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Jan 20, 2009 | Disney 13" TV
Dark Translucent Rectangle appears in front of picture
Go into the customer menu and find the "closed captions" heading. Within the closed caption you will find "TEXT". If you turn off closed captions or the text, whichever you menu lets you do, your rectangle will go away. Hope this helps
Dec 21, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No pic
SOUNDS LIKE YOU HAVE A BAD Z-SUS BOARD...LOOKING FROM REAR OF SET WITH BACK COVER OFF..ITS ON RIGHT SIDE..CALL ANDREWS ELECTRONICS IN CALIFORNIA WITH MODEL #..THEY WILL GIVE YOU A PRICE AND PART #...JOE ACE
May 15, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Blue rectangle at bottom half of screen??
Try to change the Caption mode: Press ACTION to display the MAIN MENU Select TV - CAPTION - OFF It should help.
Sep 12, 2005 | Panasonic PV-M2058 20 in. Combo
Mitsubishi WS-65809 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
