Question about Coffee Makers & Espresso Machines
I want to know the cost and the weight of 9-inch and 5-inch hand held grinder of 230volt single hase respcttively. thanks Kingsley A
  • Coffee Maker... Master
  • 32,281 Answers
I suggest you Google the Internet for these grinders. You can check the specs of the grinders from different manufacturers.
Posted on Dec 06, 2012
I'm looking for a handle for a power devil 9 inch angle grinder.do you know the size in mm thanks
Dear Mark,
9in = 228.60mm
Formula:
mm = in/0.039370
Fare. Well
Dec 08, 2014 | Saws
Compress calipers on rear brakes of 2008 ford fusion
Thanks for the info, but I found cheaper way. If you have a grinder, you can use the tool that comes with the hand held grinders it fits in the holes. I saved any where from $20 to $100. Don't waste your money go and buy a grinder if you don't have one, you will kill 2 birds with one stone.
Apr 14, 2012 | Cars & Trucks
HOw do I change grinding wheels on a 6 inch Craftsman bench grinder? Thanks.
There should be a guard over the wheel, held by several screws. Remove this. The nut holding the wheels loosen in the same direction the wheels turn so this would be anti-clockwise for the right hand wheel and clockwise for the left wheel. When replacing the wheel, ensure you replace the cardboard or rubber washers on the wheel. These spread the pressure evenly when the nut is tightened.
Apr 25, 2011 | Craftsman Garden
( I'm Spanish..and leave in Spain)..well...I go change the front whell of my VTX 1800C'02...my mechanic..d'ont know the size of original rim...¡ and I..so ¡¡..(please,sorry my...
Here are all the specs for your bike,Please take time to rate this a fixya.
2003 Honda VTX1800 Retro Spoke
Engine Type: 1795 cc, 4 Stroke - Liquid Cooled - V Twin
Engine Bore and Stroke: 101 mm x 112 mm
Compression Ratio: 9:1
Valves SOHC, 3 valves/cylinder
Carburetion: Programmed Fuel Injection (PGM-FI) with automatic choke
Ignition system:Solid-state digital, two spark plugs per cylinder
Claimed Horse power:107 hp (79.8 kW) @ 5000 rpm
Maximum Torque: 163 Nm (120.2 ft. lbs) @ 3000 rpm
Transmission type: 5 speed
Drive:Shaft
Starting: Electronic
Suspension - Front: 45mm inverted fork, 130 mm travel
Suspension - Rear: Dual shocks with five-position spring-preload adjustability, 100 mm travel
Front Fork - Rake & Trail Angles: 32 / 163 mm (6.4 inches)
Tire- Front: 150/80-17
Tire - Rear: 170/80-15
Brakes- Front:dual 296 mm discs with 3-piston calipers
Brakes - Rear: single 316 mm disc with 3-piston calipers
Overall - Length: 2456 mm (96.7 inches)
Overall - Width: 932 mm (36.7 inches)
Overall - Height: 1128 mm (44.4 inches)
Seat Height: 693 mm (27.3 inches)
Wheelbase 1715 mm (67.5 inches)
Ground clearance 130 mm (5.1 inches)
Fuel Capacity: 17 l (4.5 Gal)
Dry Weight (without fluids): 320 kg (705.5 pounds)
May 16, 2009 | 2003 Honda VTX 1800 Retro Spoke
CAN YOU TELL ME THE WEIGHT OF A BENDIX KING EPH 5141 HAND HELD RAIDIO WITH A **** SHELL BATTERY HOLDER
The Bendix/King LPH 5141 radio measures 9" x 2¾" x 1½" (not including antenna). ... Weight: 2 pound 4 ounces with LAA 0115 battery pack, antenna and holster
Nov 28, 2008 | Computers & Internet
Grinder Types
Bench grinders are perfect for sharpening cutters, bits, blades and hand tools. Any piece that needs smoothing, shaping, or polishing can be done at the bench grinder. Straight grinders or angle grinders are portable, handheld tools with wheels that range from 4 to 9 inches. They are the best grinders for working on pieces that may be too large to fit at a bench.
Aug 27, 2008 | kawasaki 7" or 9" Angle Grinder
Safety Problem
Always protect your eyes - wear only an approved eye or face shield
Aug 27, 2008 | Dewalt DW824 5" Electric Angle Grinder
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
