Question about Motorola Mobility WX160 Cell Phone
Charging solution charger no respond
    Master:
  • 368 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Dec 06, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Motorola Mob... Master
  • 1,001 Answers
  • Enjoy best product with smart IC intelligent identification your device electricity to protect your device,Intelligently detects your devices to deliver the fastest possible, while avoiding overloading, overcharging and overheating.
  • QC2.0 Applicable Phones:Samsung Galaxy S6/S6 Edge/Edge+, Note5, Note 4/Edge, Nexus 6, Sony Xperia Z4, Z4 Tablet, Z3, Z3 Compact, Z3 Tablet Compact, Z2 Tablet, Motorola Droid Turbo, Moto X 2014, HTC One M9, HTC One (M8), LG G4, Asus Zenfone 2, etc.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 24, 2016
Problem with USB Charger Doctor
May be your USB charger faulty.If very old better replace.
Sep 22, 2017 | Cell Phones
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Not turning on
Be aware that most cameras, when connected to a computer or to a charger won't start up.
Please try to charge the battery (batteries) on an external charger.
But if the charger does not "see" the battery, the battery must be defect.
By "see" I mean, when you place a battery on a charger, the charger will respond with a light, to indicate it has a battery and started the charging process.
Jan 05, 2014 | Canon Cameras
Battery is not charging
Does it NEED a charge? The camera can get screwed up. It has to turn ON to charge. For the most reliable charge do NOT use the computer. I use my computer to 'top off' the batteries. If they are really dead I use wall charger.
Jul 22, 2017 | Nikon S9200
A Sony Clie PEG-N610C has been in storage for years(it appears unused). Neither the AC charger or the cradle charger will make the charge indicater light respond. It is completely dead in all respects. Can...
Since the battery is within the unit it can leak or go BELOW the threshold level of the cell wherein the charger will not work to charge the unit. However if you can confirm the battery voltage to be below, use a multimeter to check, then before replacing use a JUMP START with an external limiter DC bench supply , you can use a series resisitor of about 47 ohms with a 6-9 VDC.
If the battery takes up voltage the see if the charger will respond and the set will power.
Sep 30, 2011 | Sony CLIE PEG-N610C Handheld
The Responder LC remote for my Viper 5901 will not charge. What can do I do to fix this? I have only had this system for less than 2 months.
Plug the charger into an outlet. Plug the charger into the remote, unplug the charger from the remote. Repeat until "charge" appears on screen of the remote. You may have to repeat the process approximately five times until charge appears. There was an issue with the batteries in the remotes having to be reset. If this does "fix" the issue, your problem may be with the charger itself. You can use any usb charger to charge the remote, i.e. phone car charger, computer, etc.
Feb 02, 2011 | Viper 5901 Security Remote Start System
Charging no respance
Hi, problem can be solved. When charging a phone and it does not respond,it means that either the charger or the charging port where you fix your charger in is faulty.
First you can try and use another charger to check if phone will charge. If it charges, that means the charger needs to be replaced,but if not charging,charging port will need to be replaced .
Take care.
Jun 09, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Charge port is dead. I plug in the battery charge chord or the car charger and the phone doesn't respond.
You have tried to charge in different ways and still the phon is not responding becuase of some problem in charge pin in the mobile.Contact your nearest vendor they ll change the pin for you and the mobile will get the input(charge flow)
Nov 03, 2009 | Samsung SCH-a930 Cellular Phone
My Nokia 6500c battery is on empty and won't take a charge
are you sure that the charger you are using is good & working?if you are sure that it is working,what is the response of the celphone display when you take a charge,doest it appear not charging?or no response at all?..if it doesnt respond and your charger is working,then the problem is on your celphone charging regulator.But,when it is responding when you take a charge but it does not store too much in your batery,then the problem is 100% on your batery,and you need to replace it for a new one.
Nov 02, 2009 | Cell Phones
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Motorola Mobility WX160 Cell Phone Logo
80 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
