Question about Acer Aspire 5315 Notebook
Linking c++ & msaccess
I'm arun doing B.Tech It 2nd Year
I dont want any software
I want to know how to store the datas gahtered by c++ into msaccess as a database file
For eg; in my college i'm no having a project named LIBRARY MANAGEMANT SYSTEM for which i have to write codes in c++,
get the inputs such as student name,roll no,etc & it is to be stored in the msaccess as a database file,but i dont know how to store it,i.e;the way to write code in c++ as well as to link the msaccess.
Please provide me the info in steps
  • 158 Answers
Posted on Jan 12, 2009
  • Prashant Bharadwaj
    Prashant Bharadwaj Jan 12, 2009
    I got this sample from 123eng.com
    // This program connects to an ODBC data source called "db97". It then
    executes a SQL statement “SELECT Model
    #include
    #include
    #include
    #include
    #include
    #include
    int main(void)
    HENV hEnv = NULL;
    // Env Handle from SQLAllocEnv()
    HDBC hDBC = NULL;
    // Connection handle
    HSTMT hStmt = NULL;
    // Statement handle
    UCHAR szDSN[SQL_MAX_DSN_LENGTH] =
    db97"; // Data Source Name buffer
    UCHAR* szUID = NULL;
    // User ID buffer
    UCHAR* szPasswd = NULL;
    // Password buffer
    UCHAR szModel[128];
    // Model buffer
    SDWORD cbModel;
    // Model buffer bytes recieved
    UCHAR szSqlStr[] = "Select Model From
    Makes Where Make='Vauxhall'"; // SQL string
    RETCODE retcode;
    // Return code
    // Allocate memory for ODBC Environment handle
    SQLAllocEnv (&hEnv);
    // Allocate memory for the connection handle
    SQLAllocConnect (hEnv, &hDBC);
    // Connect to the data source "db97" using userid and
    password.
    retcode = SQLConnect (hDBC, szDSN, SQL_NTS, szUID,
    SQL_NTS, szPasswd, SQL_NTS);
    if (retcode == SQL_SUCCESS || retcode ==
    SQL_SUCCESS_WITH_INFO)
    // Allocate memory for the statement
    handle
    retcode = SQLAllocStmt (hDBC, &hStmt);
    // Prepare the SQL statement by
    assigning
    it to the statement handle
    retcode = SQLPrepare (hStmt, szSqlStr,
    sizeof (szSqlStr));
    // Execute the SQL statement handle
    retcode = SQLExecute (hStmt);
    // Project only column 1 which is the
    models
    SQLBindCol (hStmt, 1, SQL_C_CHAR,
    szModel,
    sizeof(szModel), &cbModel);
    // Get row of data from the result set
    defined above in the statement
    retcode = SQLFetch (hStmt);
    while (retcode == SQL_SUCCESS ||
    retcode
    == SQL_SUCCESS_WITH_INFO)
    printf (" %s
    szModel); // Print row
    (model)
    retcode = SQLFetch
    (hStmt); // Fetch next row from result
    set
    // Free the allocated statement handle
    SQLFreeStmt (hStmt, SQL_DROP);
    // Disconnect from datasource
    SQLDisconnect (hDBC);
    // Free the allocated connection handle
    SQLFreeConnect (hDBC);
    // Free the allocated ODBC environment handle
    SQLFreeEnv (hEnv);
    return 0;
    http://www.123eng.com/sourcecode/c++/alg...
Hi My ps3 doesnt load games from bluray disc anymore, it plays audio cds.... this happened when i installed the latest update 3.56, i backed up files and formatted disc and i could load games again from...
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. There are many videos on youtube if you would like to do it yourself (I would advise you not to). I recommend that you find a technician who has experience. There are many things that can go wrong.
If you do, you must disassemble your drive and take out the laser to see exactly which laser you will need to purchase
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
I have a 1993 mr2 and need an engine loom diagram for when i fit the replacement engine
I can help! Are you doing a N/A to turbo swap? Or just engine for engine? Mostly year for year will be the same...JDM or USDM. Depending on year...My first suggestion would be to go to Toyota and buy the 2 Big Green Books for your year. They have FULL wire diagrams amongst COUNTLESS things you will need to know. 2nd...I would go to MR2 tech .com...They have most of the pages of the BGB there. Anything you need let me know! Ive done many swaps in the 2nd gen. Good luck!
Apr 06, 2010 | 1993 Toyota MR2
Data
go to the bios system restore that from there and if u dont know how to do that then just get ur pendrive scanned and move to a nearby tech store he will store it in bios and then he will formate it with bios he will charge around 200Rs
Sep 21, 2009 | Transcend (589307) Media
How to link vb 6.0 to msaccess?
You Need ODBC to solve your link... ODBC is a gateway. Can Access by Microsoft Access or VB in same time... Note: Please in Code Programming you must lock or unlock you data if you want application running same time..
Jul 20, 2009 | Microsoft Computers & Internet
How to connect 3 tables ang get report
You would create relationships between your tables assuming there is a correlation in the data you are using.
Feb 15, 2009 | Microsoft Computers & Internet
G-Tech drive broken
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 11, 2008 | GTech G-Tech G-Drive Mini 2.5 Portable...
Connection code
_ConnectionPtr con; cn.CreateInstance(__uuidof(connect));
OLEDB cn->Open(L"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\database.mdb;Persist Security Info=False","","",adOpenUnspecified);
ODBC cn->Open("Driver={Microsoft Access Drive (*.mdb)};;Persist Security Info=False;Dbq=C:\mydatabase.mdb;Uid=Admin;Pwd=;)
I hope this helps.
Thanks, Raphael
Aug 07, 2008 | Wizoo Darbuka
DRIVER REQUIRED FOR rELIANCE DATA CARD MODEL MC315+
Direct Download
http://download.it168.com/driverfiles2/0432/ZTE_MC315_drv10.exe
Jan 08, 2008 | IBM ThinkPad R40 2722 Notebook
Hard drive crash
if your HD cannot be detected anymore..then there would be 90% chance that your data's cannot be retrieve. however, if it is still functional as a secondary drive but the partition is damage..try using FileScanvenger to retrieve the data.
Oct 25, 2007 | Computers & Internet
Acer Aspire 5315 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
