Cmos is down on Phillips Freevents LX 2000 mini pc
Cannot find cmos battery
3 Suggested Answers
tjaipuria
  • 77 Answers
SOURCE: i need to obtain a free down load of the
Hi friend, please follow the link provided below just click on it or copy and paste in your address bar.
http://www.user-guides.co.uk/download/instruction/instructionmanual/instruction-manual-philips-freevents-lx2000-mini-pc.html
Please get your manual from here.
I hope this will help you. Plz vote Thanks.
Posted on Sep 25, 2009
joecoolvette
  • 5660 Answers
SOURCE: I have a phillips freevents desktop pc which
Not much information out there Steve on the Philips Freevent 9602/05 Desktop Computer.
This is from Techguys.com,
http://support.thetechguys.com/layout.aspx?ID={6ac70071-61fe-4e67-b886-1761c0b50c92}&CatID={b9f15b97-d311-4395-aceb-14919d4a7fda}
Pretty impressive except for graphics. If it's an Nvidia GeForce 8400GS with 256MB's of DDR2 graphics ram, (Graphics Adapter Card), I would take it out, and fly it at the neighbors barking dog.
Just my opinion.
With no Support for the Philips Freevent computers, (Made or acquired by the Dixon Group), I can't even see what the computer case looks like.
1.Computer unplugged from the surge protector, computer case open.
TOUCH the metal frame of the computer case, BEFORE you reach inside!
Your body carries Static electricity. Static will fry out your computer hardware components in a Flash! You may not even see it, or feel it!
Computer unplugged you're safe. Touch the metal frame, your computer is Safe! [Work on a table. IF you get up for any reason, when you return, TOUCH that metal frame again!]
Unplug all of the power cables to your peripherals, (Harddrive, CD/DVD drive/s, etc.), and to the motherboard, (You should have two connections at least. A 20 or 24-pin ATX motherboard connector, and a 4-pin ATX square connector. The 4-pin ATX power cable is used for Pentium 4 and above processors. Since you have an Intel Core2 Quad, you have one. You may have a FAN 1 and FAN 2 connector also)
(Harddrive power connector is a SATA power cable. Is thin, and long. There are 15 pin contacts inside it. The 7-pin, 90% bent elbow is the DATA connector. Also called Signal cable. It is not a power cable. You have a SATA harddrive)
This link explains the various power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html
Now go to the back of the computer. Since you have the computer open, you can see the power supply. It's a rectangular box shape. There are four Philips head screws you remove from the back to start to take it out. Two at the top, two at the bottom. One of the bottom one's is more to the inside.
Come around now to the inside of the computer. Computer manufacturers use various methods to secure the power supply in place. Older ones just used those four outside screws, and maybe one on the inside to a strip of metal on the power supply.
Newer computers have evolved from this.
Some use a plastic locking device, to secure the power supply inside the computer case. The device has a plastic arm which is gently eased down past a lock tab, then the arm is swung to the outside. (Watch it! Advise holding your hand underneath as it may fall!)
Some use metal for the above device.
Some have a sliding lock. Usually made of plastic. The power supply has a tab of flat metal at the outside top. The sliding lock holds the tab up.
The manufacturers information about the power supply may be on a sticker, or label on the side of the power supply, or it may be up on top.
You have to drop the power supply way down to see it, or remove the power supply fro better clarity.
IF you see - ATX12V2.X on the label, you have just a plain Ol' ATX power supply. (The X stands for whatever version it is. 2.0 is an older version. Went to 2.1, and so on)
Your concern is the shape, and size of the power supply, the needed power cables to match what you have, and the needed Wattage.
(There is one more area of concern that I should mention. Didn't want to make this seem complicated.
Computers use various voltages. They use 3.3 Volts, 5 Volts, and 12 Volts. They are going away from using 3.3 Volts.
A computer power supply delivers these voltages.
1.The Orange insulated wires deliver 3.3 Volts
2.Red is 5 Volts
3.Yellow is 12 Volts
There are 3 Main power RAILS used in a power supply. The voltages mentioned above use these. The Main one to be concerned with is the 12 Volt Power Rail.
Current is measured in Amperes. Amp's for short. It is an A used on a power supply label.
12V32A is 12 Volts at 32 Amp's.
IF, you will be using a powerful graphics card in the future, you need enough 12 Volt Amps for the graphics card, and the rest of the computer system.
The OCZ StealthXStream 600W put's out 728.8 Watts if needed, and reliably. Reliably meaning it won't burn up, and will keep on working for a Long time. (If you keep it,and the inside of your computer clean. Use compressed air for computers in a can)
Has FOUR - 12 Volt power rails. Each one is capable of 18Amps.
You can total that up to 72Amps!
Has all the power cables you'll need, and more for the future if you need them.
Not supposed to advertise for a company, but I'm sold on this power supply!
Just my Opinion.
Posted on Nov 03, 2009
Testimonial: "Thanks for your wealth of information althoughit seems very daunting to a laymen, this pc which I am regretting purchasing now is just a large screen"
Philips freevents lrpc 7500
From what I've read online, there is not much out there as far as documentation and finding the battery is underneath and difficult to locate. The poster did not say what it looked like but is probably the size of a watch battery, i.e. CR2032 or CR2016, etc...
Aug 15, 2014 | Computers & Internet
Hp mini 110 netbook wont start up
the CMOS battery is most likely in need of replacement. I had the same symptom on my wife's mini and replacing the CMOS Battery correcte
Jan 20, 2013 | HP Mini 1000 Netbook
Need to know where bios jumpers are on a dell inspiron mini 1012
I don't think a laptop has them. Removing the CMOS battery for a few hours had no effect?
Dec 28, 2012 | Dell Inspiron Mini 1012 Netbook...
The battery charge light shows green, but the screen is black and no boot. How do I get to the CMOS battery? THANKS.
Hi cqs2000.
Do the following:
"To "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}.
  • paul7of9_182.jpg Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
paul7of9_181.jpg Replace the "CMOS battery."
  • Next, "Only plug-in the "Power Adapter" into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!"
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 15, 2011 | HP Pavilion xh485 Notebook
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
I need to obtain a free down load of the instruction manual for a philips freevents lx2000 mini pc
Sep 24, 2009 | Philips Televison & Video
My phillips freevents x55p had gone into a sleep mode. when i tried to start it the screen flashed and then everything died. It was on ac power with the battery fully charged. it does not repond to the on...
removed battery pack. it then ran ok on mains power adaptor. battery but would not run either on battery alone or on battery + mains. battery pack is faulty.
Jul 31, 2009 | E-Machines eMachines Desktop PC
Where is the cmos battery located where is the Acer Aspire 5630 CMOS battery located? can i have some image or photo?
u have to open back side of laptop the cmos cell is on the motherbortd chi[pset.open back side.
Mar 24, 2009 | Acer Aspire 5630 (LX.AG50J.058) PC...
Set a power on password and cannot remember it for compaq c300
we need to remove the battery (cmos) for a bit to clear the passwords, heres how:
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the
computer is off or in hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Loosen the Phillips PM2.5×5.0 captive screw that
secures the memory/Mini Card module compartment cover
to the computer. (bottom of laptop)will see memory chips or slot when the cover is opened.
5. Lift the right side of the cover and swing it up and to the
left and remove it.
6. Make note of which antenna cable is attached to which
antenna clip on the Mini Card module, and then disconnect
the auxiliary and main antenna cables from the Mini
Card module.
7. Remove the two Phillips PM2.0×4.0 screws that secure the
Mini Card module to the computer.
8. Remove the Mini Card module by pulling the module away
from the socket at an angle .
Reverse the above procedure to install a Mini Card module
9. Remove the RTC battery from the socket on the
system board.
10. Wait approximately 5 minutes.
11. Replace the RTC battery and reassemble the computer.
12. Connect AC power to the computer. Do not reinsert any
batteries at this time.
13. Turn on the computer.
All passwords and CMOS settings have been cleared.
I leave the new password field blank unless you have worries about someone changing your settings in the BIOS.
Oct 07, 2008 | Computers & Internet
Computers & Internet Logo
262 people viewed this question
David Payne
David Payne
