Question about Miele Vacuums
Overheating and not sucking properly
It keeps over heating and is not vacuuming well
  • ola3815
    ola3815 Dec 08, 2012
    Thank you, we may just buy a new one. Although we will try to get it fixed due to environmental concerns....
    Cheers
  • 32,281 Answers
You most like have a blockage in the vacuum hose or the filter is choked with dust. Clear the blockage and filter and the suction will return to normal.
Posted on Dec 06, 2012
3 Suggested Answers
gokulegv
  • 144 Answers
SOURCE: My vacuum cleaner is not sucking. It's overheated and stopped
In this case it is motor problem, you can sort out only by calling the technician. Call the customer care and check out the cost for repair, if it is very high you can go for a new one and be in peace of mind.
Thank you.
Posted on May 08, 2010
  • 430 Answers
SOURCE: Vacuume cleaner not sucking up properly. Have
Check to see taht with no belt in place the brush roll turns freely.There should be no resistance. If not remove hair and thread from ends of brush
Then check the leveling screws on the end of the brush to be sure they are adjusted evenly.
Install the carpet head with the brush raised off the floor and lower with the pedal1 click at a time to carpet level just low enough to skim the surface, then try 1 click lower.
Posted on Sep 08, 2009
My shark proffesional nv502 vacuum wont power on. My daughter sucked up a sock and it shut down to avoid overheating the motor I guess. Well--3 days later andit still wont turn back on. Is there a reset...
it should start after awhile is it the whole machine or just the brush bar. oh there is no reset from what i read.over heat motor it shuts down till it cools.
Feb 08, 2015 | Shark Rotator Professional Lift-Away...
Vacuum not sucking
Check for a block in the hose and the bag is in properly allowing the lid to latch.
Jan 09, 2014 | Miele Vacuums
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
My vax hoover performance 2200 keeps overheating and cutting out after only 10 minutes
mine too.. I got local place to do a deep clean (sic) of all the filters but its made little difference. Hardly does a room before cutting out and then you have to wait an hour for it to cool down. am veryy disapointed
Jul 04, 2010 | VAX Appliances 2000 Canister Vacuum
Thank you.
May 08, 2010 | Sanyo Performax SC-U126 Vacuum
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
The vacuum shuts down once it's used for about 20 minutes - overheating? If anybody has any ideas, give me a shout.
Seems to be a common problem with the Euro-Pros. They happen to wrap their motors with a foam filter. This acts as an insulating blanket, retaining a ton of heat. I removed mine, and so far, it works a lot better.
Oct 26, 2009 | Euro-Pro UV209 Upright Vacuum
Turning off
hi
sounds like its overheating dut to either a blockage or dirty filters
Feb 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuum cleaner
What brand vacuum is it?
Feb 24, 2008 | Vacuums
Sucked up some leaves and now dyson will not turn on
Machine is probablyclogged. Vac is probably turning off because it is overheating.
Dec 01, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
254 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
