Question about HP Compaq Presario V6000T Notebook
Just now i purchased a HB - 575 dynamic stereo headphone for my PC,how to connect it?
I have recently purchased SONY MDR-DS6500 wireless headphones. Wireless transmitter have two inputs (1) Audio In : Optical Digital Input (2) Analog Stereo Input mini jack. I would like to hook it up to my...
Its all about the quality of the converter in the Headphone unit.
If the quality is lower than the quality of the converter in the receiver, then using the head jack is a better idea. Since there is more room, power, and money going into the receiver, it may be better
I do not believe that there is a cheap way to connect to the headphone with optical audio
The only way to be sure though, is to test it and see. Connect your computer to the receiver with HDMI, play audio through, and compare it to when you just connect your computer to the headphones, via optical audio
Oct 21, 2013 | Sony Audio Players & Recorders
Can i hook up my PC to my sterio system through the headphone jack on the stereo to the PC HEadphone jack? been trying to get it to work on Auxilary but no sound :( please help
If you are still working on the question you asked about. This is what I would do. One of two things:
First: purchase an adapter that goes from your laptop 3.5 mm headphone jack to the microphone input if there is one.
Second: Would be to purchase what is called a "Cassette Tape Adapter". This will take your 3.5 mm headphone jack and play it through your cassette tape area of your stereo.
I hope one of these is a solution that will help you. -- wicc --
Aug 16, 2012 | Computers & Internet
Were is adio red and white for sound when laptop conects to baird 42 inch
Connecting a laptop to a tv is usually achieved by the use of an audio cable with a 3.5mm stereo plug on one end, and male Red / White RCA connectors on the other end.
Plug the 3.5mm stereo plug into your laptop "headphone" socket, and connect the Red / White RCA connectors to your PC-in audio RCA sockets.
If you tv's PC-In only supports the 3.5mm audio socket, then purchase a lead with 3.5mm stereo plugs on both ends.
Cheers
Sep 04, 2011 | Audio Players & Recorders
Does my HP dv9449us has HDMI port? Can I connect it with my tv using this cable or what cables do I need? We have LG LCD tv.
Your laptop does not have a HDMI port. You only have VGA, you have to purchase a VGA to VGA cable VGA is video only interface. So you will need it along with the stereo audio cable
http://pctvcables.com/vga-with-audio-pc-to-tv-cables.html
Note that the stereo audio cable shoulb be connected from the headphones jack on your laptop to the headphones jack on you home theater system if you have one or buy this adapter plug the stereo audio cable coming from the laptop into it and connect it to the stereo audio in (red and white audio)of your tv
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Aug 18, 2011 | HP Pavilion DV6449US Notebook
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
My volume wheel isn't working, as well as the mute button. Model SK-9625. The computer is Acer Aspire X1300. Using headphones, Sony Dynamic Stereo Headphones MDR-V150. Speakers not plugged in, since I...
I had the same problem. For me it helped to turn on Hotkey utility (was already installed). If you do not have it, try to google it.
Hope it helps
May 26, 2010 | Acer NSK8458AN Keyboard
Beyer dynamic dt 100 headphone 400ohms. There's
It could be that the Earth connection has become detached in the cable or plug somewhere!
Oct 13, 2009 | Beyerdynamic DT 100 Professional...
Radio shack headphone HB-575 incompatibility with SKYPE
Very simple get another heaset and trying - different type as skype uses " their specific interogation drivers which it seems are not compatible with your series headset.
Feb 15, 2009 | HP Compaq Presario V6000T Notebook
Microphone
6720 doesnot have an onboard MIC.
Please plugin an external mic( typically the ones you use with headphones- ) and try.
Should work.
Cheers,
An example of the headphone + mic is
http://cgi.ebay.in/STEREO-SOUND-QUALITY-HEADPHONE-HB-575_W0QQitemZ370068749474QQihZ024QQcategoryZ11682QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 13, 2008 | HP Compaq Presario V6000T Notebook
HP Compaq Presario V6000T Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
