Hello, I recently picked up a Tascam us-144 MKII. My OS is windows 7 32 bit. And we run FL studio 10. While playing some of our tracks every once and a while we experiance loud cracking and popping sounds followed by a delay between what our screen says and what we hear. This will occur more often if we replay our tracks or switch plugins or write a scale ect. The only way we have found to temporarily fix it is to go to the mixer and switch drivers in and out. Are there any permanent solutions out there?
  • 3,606 Answers
Hello you can download drivers and the manual here:
http://tascam.com/product/us-144mkii/downloads/
You need adobe reader to read the content in the manual.
It sounds like the gain or mic level is set too high or a defect cable.
Try also to renew the sound driver on the pc.
Try also to lower the the input gain on the playback device.
The FL studio homepage:
http://www.image-line.com/documents/flstudio.html
Good luck
Posted on Dec 13, 2012
3 Suggested Answers
  • 146 Answers
SOURCE: not soppot asio in fl studio
Try a different ASIO driver. I would say that the sound card that you are using does not come with an ASIO driver so the software can't use the card correctly. I recommend ASIO4ALL. It is free to download and works with almost all soundcards and audio devices in Windows. You can get it from www.asio4all.com.
Best of luck.
Cheers
Posted on Jan 01, 2009
allanster
  • 60 Answers
SOURCE: tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Posted on Feb 03, 2009
My tascam us-144 only plays in left ear, and I do not have cubase, need fix!
Hello you can download a manual and other stuff here:
http://tascam.com/product/us-144/downloads/
You need adobe reader to read the content.
Good luck
Dec 12, 2012 | Tascam US-144 Sound Card
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
TASCAM US 144 and Mac incompatible???
A lot of the Audio drivers or Tascam and m-audio devices really only work for windows 32 bit reason i tried installing the same stuff for windows 64bit won't work in less u have vista 64bit But regular windows 32 bit works with every program out there. The mac if it did work it should pick up a signal if it worked properly but it sounds like the mac don't read it even with drivers .
This also could be a problem with your device if you had the same problem with it last time. replace it with a new one and try the install again on your computer and see if it works after that.
Aug 14, 2009 | Tascam US-144 Sound Card
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 144 sony acid pro 6 no sound from midi track
Feb 01, 2009 | Tascam US-144 Sound Card
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Tascam 144
Check pan control and then try another set of phones...accordianman
Feb 12, 2008 | Tascam US-144 Sound Card
Tascam us 144 computer won't pick up microphone
OS? Try restoring to an earlier time if you're running XP, Vista, or 2000. Answer this and I'll try to get a fix for you...accordianman
Jan 05, 2008 | Tascam US-144 Sound Card
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
