Want to change video card in Sony VGC-RA842G
There is a black plastic bracket with a slot attached to the power supply that the video card is sitting in. I can't figure out how to remove the power supply to get the black bracket off the video card. I don't want to snap the bracket off as I'm not sure what it is attached to.
    Genius:
  • 1,102 Answers
The power supply usually has screws on the back of the tower
unplug from motherboard and and anything else
just remember where to plug things back in then remove it
need more info to help further
Posted on Jan 18, 2009
LT23 E VIDEO SCREEN IS GOING BAD REPLACE CARD UPGRADE?
  • When I turned on my Sony VGC-LT23E, it's beeping 1 long beep and 2 short beeps, is there the Video Card issues. The screen total black. Should I replace entire motherboard? Please help,
May 07, 2012 | Sony VAIO VGC-LT23E 22" PC/TV All-in-one
My Sony VGC-RB34G is suddenly showing nothing on monitor except a sign "Check Signal Cable". I have cleaned and put back RAM tight. The fan works, I hear beeps when computer starts but no pic. I...
The computer should beep ONCE when starting-up.
More than one BEEP implies either that the video-card is not responding, or that it is not fully "seated" in its slot.
Try a different video-card in your desktop.
Aug 26, 2011 | Sony VAIO VGC-RB50 PC Desktop
More than one BEEP implies either that the video-card is not responding, or that it is not fully "seated" in its slot, or that the video-cable is not tightly connected.
Aug 26, 2011 | Sony VAIO VGC-RB34G PC Desktop
I have a Sony Vaio VGC RB-40 Desktop PC. P-4 3.00GHz. 2.00GB. Ram 32 Bit system Win 7 Home Premium 300 Watt power supply I need a video Card 1GB DDR3
Hi,since your computer is P4 3.0ghz,your looking for agp 6200 graphic card..and not the 1 gb ddr3 because this is pci-e and its not compatible with your slot..I can offer to you is the 256 mb agp video card,coz its hard to find now the 1gb ddr1 coz its all absolute now.thanks
Aug 20, 2011 | Nvidia GeForce 6200 AGP Graphic Card
Which video card i can get for gaming on this computer the vgc-rb53 vaio sony computer please help!!
You can fit any PCI Express X16 graphics card into your computer. The biggest issue that you may run into is power requirements. However, the majority of inexpensive graphics cards - ranging in prices under $80 - should be capable of gaming very well. If you're looking to go all out and make an investment in PC gaming, replacing the power supply will make the machine capable of using any video card. 1000 watt power supplies can be found online for around $100.
Feb 26, 2011 | Sony VAIO VGC-RB53 PC Desktop
Dvd drive does not open
Try sticking a paper clip directly in the middle. Slowly, but hardly pull it back so the tray opens up all the way. Then once it's pulled back completely, press eject button and it should re-align itself back on track
Apr 08, 2010 | Sony VAIO VGC-RA842G PC Desktop
I want to switch it my monitor from HD15 Mode to DVI on my VGC RB52
Assuming you have not already upgraded the system, you will need to add a video card with DVI output to your computer. You need a PCI-e x16 card and to make sure to either upgrade your power supply or choose a card that will not exceed the power supply's capacity. The original Power supply provided 305W (max.).
The alternative is to simply attach a DVI to VGA converter and stick with the on-board VGA only output but send it through the DVI port on the monitor.
I hope this helps.
(you should pay attention to heat issues if you add a video card; I've generally found that ATI cards run a bit cooler than nVidia cards for the same generation/performance.)
Mar 02, 2010 | Sony VAIO PC Desktop
Monitor reads no signal...
its not mobo...since it power up and you see the light indicator are processing ..to be sure ..when you turn on the pc..does the light for HDD is processing like blinking green/blue..if does..try to connect your monitor to other computer..if your monitor works..thats good..
if your video card is built in to mother board..the cause is one of the pin of the port is disconnected..you cannot fix this..but you can replace the video card by installing it to one of the expansion slot inside the computer...check what kind of interface for video card slot inside the computer (PCI, AGP,PCI express)..then buy that and install it. its plug and play
good luck
Mar 16, 2009 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
HELP! No video on Sony Vaio VGC-RA710G desktop
Since the power supply wasn't secured properly it actually contacted the motherboard while it was still carrying a charge. For next time, I use zap straps for all of my wires and to secure components. Try removing the motherboard and doing the power supply self test, most likely you will have to replace both the motherboard and CPU though.
May 03, 2008 | Sony VAIO VGC-RA710G PC Desktop
VGC-RB50 Display Problem
I hate to be the bearer of bad news, but I think that the MB or the processor just took a dive on you. Most likely the processor... as you are able to power up. If it were the memory or the video card, you would hear a series of beeps when trying to start the computer. And you already verified the monitor is fine.
Jan 03, 2008 | Sony VAIO VGC-RB50 PC Desktop
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
