Question about HP Laserjet M2727nf Multifunction Printer
HP laserjet m2727nf will not start up
The printer has power but when switched on it just shows HP and little arrors in the display and does not ever get to READY status, No error is displayed
we have tried unplugging it and restarting it but problem persists.
This is a remote printer located in another office so it may be difficult for me to provide you with an exact information
Thanks
James Verity
  • 2 more comments
  • Anonymous Feb 10, 2009
    I have a problem like this one. The device was hang up during the "Programming ..." phase when updating firmware and i must turn power off. After power it on "Hewlett Packard" and some arrows message displays on the screen and i can't resume or restart firmware update and device is unusable.
    P.S. Sorry for my english.
  • olehator Feb 10, 2009
    Device was hung up during "Programming ..." phase while updating firmware. I must power it off. After I power it on the same problem appears ("Hewlett Packard" and some arrows displays) and i can't use device or resume or restart firmware update :-(. I hope someone of gurus help us. Thanks.
  • raverbuch Feb 16, 2009
    I had the same problem after a few months of normal usage. Powers up and then it just stops and seems to turn off- nothing on the screen, doesn't light up, etc.
    I called service/support and they recommended the cold reset but it didn't do any good.
  • making4 Apr 02, 2009
    Got the printer lightly used from another business site, and it started fine (even got an IP address), but stopped functioning as soon as I put toner in it - now it doesn't boot at all.
I had this problem. You need to do a cold reset. To do this turn the machine off. Hold down the 6 and the # on the fax pad. Keep holding these keys down and turn machine on. After about a half a minute let the buttons go. It should do a reset. It may take up to 25 minutes to do this however my took less than one minute
Posted on Feb 11, 2009
Same problem, I called HP and they've extended the warranty because of the issues they've had with the formatter boards. They let me bring it in locally and have it repaired for free, or you can buy a refurb from them for 45.00, good deal!
Posted on May 04, 2010
I also had the same problem and the cold reset did not work. It was under warranty so a tech came out and discovered the Motherboard was shot. The machine was only a few months old and the tech thought it may have been due to a power surge. We had it plugged into a surge protector, but there was construction in the area and the tech said sometimes the surge may be powerful enough to fry right through the protector.
Bryce
Posted on Jun 18, 2009
Am getting 50.2 fuser error on hplaserjet m2727nf printer
50.2 error is an internal hardware error.
Turn off the power using the switch, and wait at least 30 seconds.
Do not use a surge protector. Plug printer directly into the wall outlet.
Power on. If the error comes back, contact HP.
Feb 25, 2011 | HP Laserjet M2727nf Multifunction Printer
How to use scanner of the said printer HP LaserJet M2727nf
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01072069/c01072069.pdf.... check this link..this is the user manual of HP laserjet M2727nf MFP Printer
Nov 10, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp m2727nf freese at boot up display shows- hewlett-packerd >>>>>
Hello ....... your formatter faulty replace them your problem will be resolved.
Oct 28, 2010 | HP Laserjet M2727nf Multifunction Printer
No display on hp m2727nf
you may require a new display panel -- if the unit is under warranty, call HP , i aM NOT CERTAIN WHAT COUNTRY OR STATE YOU ARE IN, BUT I KNOW hp IS ALL OVER THE WORLD
IF YOU NEED FURTHER INFORMATION, LET ME KNOW
Oct 15, 2010 | HP M2727NF Laserjet Printer
Faultcode 5 for HP laserjet M2727nf The scanner
This sounds like a Scanner/Flatbed Problem. "The printer report a Scanner Error 5" This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Oct 14, 2010 | HP Laserjet M2727nf Multifunction Printer
I have a HP laserjet m2727nf start after 5min go downs!
This is due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Aug 03, 2010 | HP Laserjet M2727nf Multifunction Printer
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
How re start my hp laserjet m2727nf, how delate
hold down the go button while you power on your hp laserjet.
Mar 19, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf Multifunction Printer Logo
10,235 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
