Question about Coleman 1-burner Dual Fuel Sporter Ii Liquid Fuel Stove Gas Camping Travel
The stove is not burning right and not holding pruser
Just bought a house with a Gibraltar SCR stove in it. I want to use this thing, but have never owned a stove and don't know how. What fuel? How to set the fuel in the stove, etc. Can you help?
Gibraltar makes coal, pellet and wood stoves. Stoves that burn wood pellets have a hopper and feeder auger that feeds pellets into the burning chamber. They also require electricity to work. From what I read online you should be able to burn wood in the stove but I believe the coal stoves have a smaller burning chamber.
Nov 28, 2017 | Heating & Cooling
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
Oven will not heat, control panel is eratic, gas burners will not spark
Check fuse box to see if stove is receiving power. Turn one top burn on and hold a lit match to it. if it does not light. Call gas company to see why there is no gas to your stove.
May 15, 2016 | Kitchen Ranges
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Oil system pictureoil filtur keeps blowing of oil pruser
Likey oil pump bye pass valve stuck allowing the oil pressure to go too high.
May 13, 2014 | 2000 Chevrolet Blazer
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Hello a couple of our stove tops rings intermittently work and now one has stopped working altogether. The light comes on but the ring does not heat up. Any advice? Thanks so much
Hi unplug the stove and remove the two screws that hold the top down, holding the burners, check for burned wires going to and from all burners I think you may have wires that are shorted out , or the element itself is burn out , you can check this with a ome meter, by putting each wire on the ends of the element , I hope you know how to use a meter if not write back and I will walk you though it , Just look around very carful
Feb 21, 2011 | Maytag CWE4800A Electric Single Oven
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 02, 2010 | Heating & Cooling
OVEN WANT HEAT PROPERLY FOOD DOSEN'T GET DONE
It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter or take it to a store that sells replacements ($25) and they may check it for you.
Oct 31, 2009 | Kitchen Ranges
Coleman 1-burner Dual Fuel Sporter Ii Liquid Fuel Stove Gas Camping Travel Logo
81 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
weirdtop
oldhess
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
