Question about Asko Washing Machines
What size fuse does asko washing machine take
Model W6761 front loader
  • 660 Answers
No size given, but here is the part.
http://www.repairclinic.com/PartDetail/Line-Fuse-and-Holder/8801354/1460992?modelNumber=W6761%2FStainlessSteel
Posted on Dec 06, 2012
  • 3 Answers
SOURCE: asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Posted on Aug 05, 2008
  • 351 Answers
SOURCE: Asko W6761 washing machine frozen
it looks like the control board needs replacing the part no is on the board and starts 80,but first can you get into the menu option or has it locked you out
Posted on Aug 28, 2008
Macmarkus
  • 2605 Answers
SOURCE: i have an asko quattro
Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
Posted on Nov 01, 2010
  • 351 Answers
SOURCE: Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Posted on Aug 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
Error message: Thermistor Fault
yes it is serious as it indicates an over heating condition probably on the motor or control panel
May 17, 2015 | Asko W6761 Front Load Washer
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
Wash motor fault
If so you an check if the motor is working separately out of the circuit. If so there is fault on the control drive circuit and so the output to the motor drive could be a suspect.
Feb 28, 2013 | Asko W6761 Stainless Steel Front Load...
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
1. Power it on
6. Power it off and on, again
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Door not closing
If you dont have a problem with the catch, then either your door latch is defective or possibly a wire has burnt off or come loose from the connecting point
Jan 27, 2009 | Asko W6761 Front Load Washer
Aug 27, 2008 | Asko W6761 Front Load Washer
Asko w6761 front loader
you can remove the grey drum paddle to get access to the inner drum stick a small screwdriver in the middle hole of the paddle and pull towards you other wise you would be better getting an ako tech to do it because ther are three panels to remove plus a clamp band.if you havent done one before it can be difficult,also check the pin trap it may have gone in ther(filter bottom left corner)
Oct 10, 2007 | Asko W6761 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
