Lenovo z470 crash while i'm installing medal of
  • 7,627 Answers
Boot in safe mode with networking. Delete game. Return/replace game.
Posted on Dec 07, 2012
mrd00d
  • 36 Answers
SOURCE: my IBM t30 wont boot up
Use Knoppix to save your data if you need to, otherwise it sounds like you may need to reinstall the OS.
ftp://ftp.uni-kl.de/pub/linux/knoppix/KNOPPIX_V5.1.0CD-2006-12-30-DE.iso (to download Knoppix 5)
You could try using the recovery console, as previously mentioned as well. If you don't need to save data, just blow it all away and reinstall XP.
RESOLUTION loadTOCNode(1, 'resolution'); If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Dec 21, 2007
ginko
  • 19396 Answers
SOURCE: Notebook will not boot
You need to get a windows install disk
Posted on Mar 08, 2008
SOURCE: My niece's Inspiron 1501 doesn't boot at all.
It is also possible that the cable to connect the hard drive to the computer has gone bad or disconnected itself. This can sometimes happen in laptops. Try checking your hard drive using the system diagnostics in the BIOS settings, or by creating a Drive Fitness Test CD on another machine (http://www.hitachigst.com/hdd/support/download.htm). If neither of these detects your hard drive, it's very likely a connection issue. If you feel comfortable doing so, and it doesn't void your warranty, you can unscrew the cover on the bottom of the laptop and check the connection yourself. Make sure you're grounded, so you don't ruin anything with static discharge. If you don't have a screwdriver that small you can usually get one of those kits at the dollar store. They're the right size, but be careful because they will sometimes strip the screws. Good luck!
Posted on May 16, 2009
joecomputer
  • 92 Answers
SOURCE: lenovo Y510 stuck on logo screen at startup
Your hard drive maybe failing. I would make a back up as soon as possible . Then I would do a dskchk, Here's how:
Double-click My Computer, and then right-click the hard disk that you want to check.
  1. Click Properties, and then click Tools.
  2. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  3. Use the following procedures:
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check. Please don't forget to rate this solution.
Posted on Jun 13, 2009
  • 1288 Answers
SOURCE: my brother laptop Compaq Presario
Fundamentally, it means that the hard drive or hard drive controller has malfunctioned. I'm assuming this is running Vista or Wndows 7 and that the hard drive is indeed a Sata drive?
(If it were running XP, the failure to deterct the hard drive could be caused by there not being a Sata driver installed, however, on Vista or 7, this should not be the case, UNLESS you changed the OS from what was installed originally?)
I would try to prove this by testing the laptop with another working sata hard drive and if that one is recognised in the Bios, then it comes back to your original hard drive being faulty. If this IS the case, then as its 3 months old and still under warranty, I'd take it back without tampering with it any further
Posted on Apr 18, 2011
Cant install medal of honor without install code
That's not a problem, that's a feature. Your install code is printed on your software packaging.
Mar 06, 2010 | Electronic Arts Medal of Honor Allied...
Game crashes at the same point of the mission level.
well as the game says you have hard drive issues. have fixed or replaced.
Oct 06, 2009 | Electronic Arts Medal of Honor Allied...
Hello Have just bought Medal of Honor Allied Assault Deluxe Edition - installed it, but when I want to play it crashes to desktop. Any ideas? Simon
Vista - try to run as administrator
XP - try uninstall it, reboot and press F9, go safemode, install it in safe mode. if nothing happens reboot again and login to your normal user and install the game. now it should work fine =)
Dec 31, 2008 | Electronic Arts Medal of Honor Allied...
Problem with Ati radeon graphic card
The ATI Radeon X1050 video card is unfortunately not supported by the game. You need atleast a X1300 to play the game. But you may try updating the game itself by going to the medal of honor website and download the patch. Then restart your computer and try starting the game.
Nov 07, 2008 | HIP Medal Of Honor: Airbourne for Windows
Medal of Honor
make sure you have the proper directx installed.......
reinstall the game....i think some game files might have corrupted due to virus.....
Sep 19, 2008 | Electronic Arts Medal of Honor Allied...
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
