Question about Universal Kreepy Krauly In-Ground Pool Cleaner
Can i use a kreepy krauly on a liner pool
I have a inground pool which is a liner can i use a Kreepy Krauly in it ?
  • 11 Answers
SOURCE: Hi my kreepy krauly wont stay flat on the bottom
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Posted on Mar 27, 2010
Coastsider
  • 331 Answers
SOURCE: My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Posted on Apr 14, 2010
Testimonial: "Great thank you for this info...I believe that I need to buy another type....too many problems with this type of cleaner."
Coastsider
  • 331 Answers
SOURCE: Kreepy Krauly keeps getting stuck on the pool wall
Manufacturer may have an additional accessory bumper you can get to prevent this. Depends on your model
Posted on Apr 16, 2010
  • 990 Answers
SOURCE: Our kreepy krauly will not stay suctioned to the
Check for air leaks in your hoses, your pump or in the plumbing system. Also check for clogs in your pump impeller if you have any problems with your basket. Good luck.
Posted on Apr 24, 2010
Geekman
  • 32281 Answers
SOURCE: Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
Posted on May 25, 2010
Kreepy krauly regulator valve won't close, it's always open so the cleaner doesn't move. There's plenty of suction,
It has debris stuck in it. Normally it is not too hard to clear it out. If you can't clear it, try to run the Kreepy without the regulator.
Aug 04, 2013 | Pentair Kreepy Krauly Inground Automatic...
BROKEN SUCTION HOSE CONNECTOR DOWN IN SUCTION WELL
Contact them direct. This is not something that can be answered by Fixya, especially as this is an Australian product and we are a North American self help website.
Pool Cleaners ' Automatic Pool Cleaner - Kreepy Krauly Pool Cleaners
https://www.kreepykrauly.com.au/Kreepy Krauly is Australia's most trusted and innovative automatic pool cleaner. Request a free pool cleaning demonstration with one of our pool cleaners today.
Kreepy Krauly Google Search
Aug 25, 2017 | Universal Kreepy Krauly In-Ground Pool...
Kreepy kraully not cleaning complete pool
If the pool hose has been connected to the Kreepy Krauly in the one position for a long time, the pool hose gets set is a position so the kreepy Krauly travels ith same path all the time. Try rotating the pool hose 90 degrees and or change the angle of the hose connector in the skimmer box.
Mar 07, 2012 | Pentair Kreepy Krauly Inground Automatic...
Kreepy krauly not cleaning whole pool
If the pool hose has been used for a long time it becomes set in a particular position. Twist the hose at least at leasr 90 degrees so that the hose is set in a different configuration and the Kreepy krauly will go to a different part of the pool.
Feb 27, 2012 | Universal Kreepy Krauly In-Ground Pool...
I have a 20X40 rectangular liner pool and my kreepy krauly stays in the deep end of the pool. I think I need to adjust the weights. Where should the weights be placed?
The first weight from the cleaning head should be adjusted so the Kreepy sits flat on the floor with the system turned off. Then you can start moving the next weight until it starts climbing the hill to the shallow end. It may take a few times but if you get the weights set correctly it should work.
Aug 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
Kreepy crawly keeps stopping but nothing is blocked
With Kreepy Krauly pool cleaners, it is usually something blocked so you have taken the perfect first step in finding your problem. You will also want ensure that the main drain and all suction lines are closed, except for the line to which the Kreepy Krauly is attached. Also, if this is a new purchase, it could be that your pump and filter system are too small to properly propel the cleaner.
Aug 13, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krauly seems to have good suction, but moves very slow. I usually hear a tic,tic,tic,tic, But, lately it has been tic....tic......tic Very Slow
Try these suggestions to get your automatic pool cleaner working properly:
• Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
• Check for debris in the filter or pump basket.
• Check for debris in Kreepy Krauly’s flapper. Debris may prevent flapper movement or restrict flow.
• Check the hose to ensure there are no leaks.
• Check the vacuum connection. It should be submerged so no air enters the system.
• Check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Jan 03, 2010 | Pentair Kreepy Krauly Inground Automatic...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
Need operational manual
the manual is available at this web add, thanks be sure to leave a good rating.....
http://www.novem.com.mx/mkreepy.pdf
May 12, 2009 | Pentair Kreepy Krauly Suction Side...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
55 people viewed this question
Top Universal Pool & Spa Experts
Andrew Taylor
Andrew Taylor
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
