Question about Cell Phones
I need a service manual for a SUN MRC334 mobile recycling unit, Any Idea?
When I switch it on it gives me an error 15. I have checked the filter is correct. I have checked all the pipes are tight. Any other ideas?
2 Suggested Answers
  • 143 Answers
SOURCE: Couldn't register service provider. Display shows ''LTD. SERVICE''
Its purely network problem. Dont try again and again with the same solutions. Switch off the mobile for some time, remove battery, and sim card, and put them again after some time and switch it on. In samsung, while switching on, it will show the service providers name in the start up screen. if it shows, then it should work. If it doesnt work, some problem with the sim card. try to replace it. or otherwise general operation in selecting the network shud help.
Posted on Aug 10, 2009
Smh9187 microwave stopped working. The units display works, light inside works, vent fan works, but when you put food in it doesnt make a sound.
On model SMH9187B and SMH9187ST, one likely cause is a defective bottom door switch (primary interlock) or that switch's mount is loose, misaligned, or broken. The service manuals for these models are at my site here:
SMH9187B service manual
SMH9187W service manual 1 ' service manual 2
SMH9187ST service manual
Also see my help file on door switches here.
You can order Samsung parts by part number from the Pros here.
If it's not a door switch issue, it may be a blown high voltage fuse not to be confused with the line fuse) or a relay issue on the board, which I can repair for you.
If you have other questions, feel free to contact me at my site below for more free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 18, 2017 | In Microwave Ovens
The check filter light will not go off even after I have cleaned the filter numerous times; and now occasionally the unit wil rapidly shut it self on and off repeatedly (again the check filter light is...
Apparently, the unit is not recognizing the filter change. So, turn the Master ON/OFF Switch to OFF and unplug the unit. Wait 15 minutes and plug it back in. Turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset themselves and reverted back to the original factory settings and the change filter light is now, OFF.
Hope this helps you.
Jul 08, 2011 | Frigidaire FAH106N1 Wall/Window Air...
I have lost my service Manual for my NEC 6847 Air con unit & need to download one so that i can figure out how to get the heat to work
Make sure the remote control 'Mode' setting is on 'Heat', usually an icon that looks like a small sun. Then increase temperature setting until unit switches on. Can take 7 minutes or so to give any warm air flow, but if nothing after about 15 mins, then you have a problem. - Rick
Jun 12, 2011 | Heating & Cooling
My projector going to standby mode very frequently
Is it overheating? If it is check the filters are clean and there is plenty of air flow. If not which lights are on and are any flashing then look in your manual for fault conditions. That should give you a good idea on the area of the problem. It may be a lamp issue or ballast issue it may be a detection error and the unit switches off when it thinks there is no sync pulses even though there is a picture.
Mar 16, 2011 | Sharp XR50S Projector
34788 COOL TECH,FILTER LOCK OUT,REPLACED FILTER TWICE STILL LOCKED OUT,READS FILTER ERROR
Check the filter monitor air flow differential switch is not blocked or broken. have you a manual reset after filter change?
Aug 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
How to activate gprs china phone
Automatic Activation of GPRS
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text “ACTIVATE” and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Exit and save settings
Jun 06, 2010 | Nokia E66 Smartphone
Error codes
F27 = OVERFLOW CONDITION
Did you inspect the filter for clogs I have seen this happen many times The filter is located behind front lower panel and can be white in color follow the hoses its before the pump. I have seen the filter clogged and give these type of symptoms
but here is error code F27 out of the maintenance manual
If the overflow contact on the pressure switch is closed for more than
60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs
constantly, even if PAUSE/CANCEL is pressed twice and the display is
cleared. Turn off hot and cold water faucets and unplug the unit before
servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch,
water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The timer light flashes twice about every 15 seconds
This may mean that the filters may need to be cleaned. According to service manual the unit has a "Serial reverse transfer
error at start up operation". Call fujitsu for service if the fault cannot be rectified.
I take the time to answer your questions, please rate me
Mat
Aug 28, 2009 | Fujitsu Heating & Cooling
How can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Automatic Activation of GPRS/MMS/WAP
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Select Sun GPRS
APN: “wap”
Select SUN MMS
APN: “mms”
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
Feb 16, 2009 | Nokia 6300 Cellular Phone
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
