Question about Honeywell Home Security
My Honeywell OMNI 400/600 System continiously gives a low battery signal, but the battery measures 12.3.V
I have already chenged the battery but the signal remains and the removed battery is OK.
3 Suggested Answers
  • 313 Answers
SOURCE: nimh batteries give low batt signal even when
the trouble with rechargable batteries is their voltage is low to start with even when charged. they only give 1.2 volts each instead of 1.5 volts from proper AA bateries. I use Energizer Lithiums in all my camers and they are great and last a long time. You can find cheap suppliers on eBay I use a site called 7dayshop.com in jersey (europe).
Posted on Jul 25, 2010
muntejaya
  • 10421 Answers
SOURCE: vcd plays ok display remains continiously and
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_fgt
Posted on Feb 27, 2011
2006 Chevy Envoy Denali moonroof stuck open manually close
You mean GMC not Chevy ! Chevy doesn't make the Envoy . There is no way to manually close the sunroof !
Power Sunroof Inoperative
If voltage is not measured on the sunroof switch open signal or sunroof switch close signal circuits, the fault could be in the retained accessory power (RAP) supply voltage circuit, battery positive voltage circuit, or sunroof motor ground circuit. If the sunroof motor is not being powered, neither will the sunroof switch signal circuits.
Attempt to operate the sunroof through its full range of functions in order to verify that the power sunroof inoperative fault is present.
Does the power sunroof system operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
YES - Go to Step 3
Is the sunroof in the fully closed position?
YES - Go to Step 4
NO - Go to Step 7
  1. Disconnect the sunroof switch.
  2. Turn ON the ignition, with the engine OFF.
  3. Connect a 3-amp fused jumper wire to the low reference circuit of the sunroof switch harness connector.
  4. Connect the other end of the 3-amp fused jumper wire to the sunroof switch open signal circuit of the sunroof switch harness connector, for 3 seconds.
Did the sunroof open?
YES - Go to Step 17
NO - Go to Step 5
5
  1. Disconnect the 3-amp fused jumper wire.
  2. Measure the voltage from the sunroof switch open signal circuit of the sunroof switch harness connector to the low reference circuit of the sunroof switch harness connector.
Does the voltage measure near the specified value?
B+
YES - Go to Step 13
NO - Go to Step 6
6
Measure the voltage from the sunroof switch open signal circuit of the sunroof switch harness connector to a good ground.
B+
YES - Go to Step 14
NO - Go to Step 10
7
  4. Connect the other end of the 3-amp fused jumper wire to the sunroof switch close signal circuit of the sunroof switch harness connector, for 3 seconds.
Did the sunroof close?
YES - Go to Step 17
NO - Go to Step 8
8
  2. Measure the voltage from the sunroof switch close signal circuit of the sunroof switch harness connector to the low reference circuit of the sunroof switch harness connector.
B+
YES - Go to Step 15
NO - Go to Step 9
9
Measure the voltage from the sunroof switch close signal circuit of the sunroof switch harness connector to a good ground.
B+
Go to Step 14
Go to Step 10
10
  1. Disconnect the sunroof motor harness connector.
  2. Measure the voltage from the battery positive voltage circuit of the sunroof motor harness connector to a good ground.
B+
Go to Step 11
Go to Step 19
11
Measure the voltage from the retained accessory power (RAP) supply voltage circuit of the sunroof motor harness connector to a good ground.
B+
Go to Step 12
Go to Symptoms - Computer/Integrating Systems in Computer/Integrating Systems
12
  1. Turn OFF the ignition.
  2. Measure the resistance from the ground circuit of the sunroof motor harness connector to a good ground.
Does the resistance measure less than or equal to the specified value?
5 ohms
Go to Step 16
Go to Step 20
13
Test the sunroof switch close signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 23
Go to Step 18
14
Test the sunroof switch low reference circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
15
Test the sunroof switch open signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
16
Test the appropriate sunroof switch signal circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
17
Inspect for poor connections at the harness connector of the sunroof switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 21
18
Inspect for poor connections at the harness connectors of the sunroof motor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 22
19
Repair the short to ground or open in the sunroof motor battery positive voltage circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 23
20
Repair the open in the sunroof motor ground circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Go to Step 23
21
Replace the sunroof switch. Refer to Sunroof Switch Replacement .
Did you complete the replacement?
Go to Step 23
22
Replace the sunroof motor. Refer to Control Module References in Computer/Integrating Systems.
Go to Step 23
23
Operate the system in order to verify the repair.
System OK
Go to Step 2
Jul 31, 2016 | Cars & Trucks
Does low voltage in ignition have to do with a weak battery
If the voltage drops more than is normal during the ignition cycle, this can be caused by a weak/old battery (Insufficient crank amperage) or by problems with the starter motor. Most auto part shops will test your electrical system for you for free and can determine whether the battery is having problems, the alternator is failing, or the starter motor is faulty.
Mar 28, 2014 | 2003 BMW Z4
How do I change battery in alarm system
Find the main box that has the alarm control board in it. This panel can have a 12v 4ah battery or a 12 7ah battery. Unplug the old one, plug in the new one. Make sure you put the black to black red to red it doesn't matter what order but if you do it backwards then you'll have to guy buy some small fuses. GIve it about 12-24 hours and it should clear from the keypad.
Mar 19, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
Honeywell Ademco alarm panel reads Chime BAT 11
The answer above is incorrect. If the back up battery was low it says, "bat" on the screen and that's it. Since the "11" is being displayed, zone #11 on your wireless system as a low battery.
Jan 07, 2014 | Honeywell 5804 Ademco Wireless Security...
APX alarm system reads low battery,what do we do?
The backup battery that help the system keypad/receiver unit to operate it is low in power and it is dying and in need of a new battery replacement.Traced the system back where main junktion and overide to the system box unit is should have the battery there.This battery really easy to do a replacement.The battery it is like a similar to a motor cycle battery.
Jul 21, 2011 | Honeywell Ademco/ Honeywell 6150rf Apx...
04 2.7 intrepid wont start .p0344 p0700 p0562
P0344 Camshaft Position Sensor Circuit Intermittent
P0700 Transmission Control System Malfunction
P0562 System Voltage Low
I would start with the P0562 issue. Check the battery voltage - it should be at a minimum of 12 volts (DC). You can try charging the battery with a trickle charger overnight and if the voltage does not come up to 12 volts then you should replace the battery. If it comes up to 12 volts then try starting it up if it starts you should get the alternator checked out at a garage. A simple alternator check is measuring the voltage at the battery you should get between 13.2 to 18.2 volts when the vehicle is running. The low voltage may be the cause of the other two codes. If not the P0344 indicates you may need to replace the sensor or if the timing slipped you may need to replace the timing chain / belt. The P0700 could indicate a low fluid condition or it may mean take it to a transmission mechanic.
Nov 28, 2010 | 2004 Dodge Intrepid
I need a radiator. is there any radiators that will inter change
1989 Dodge Omni Radiator
Part Number: 12553SAP0882P
Manufacturer Part Number: w5LDkcOWw5bDkMK7w5PDm8Obw5HCsw==
Part Specifications:
Core Size (in) approx: CU/BR 17-1/4 x 12-1/2 x 1-1/4, 2 ROW
Tank: PLASTIC
Weight: 8
Part Details
2.2L L4 Without Heavy Duty Cooling + Without AC - All Transmission.
This Part Fits:
1983-83 : DODGE OMNI 1.6L L4 98
1984-88 : DODGE OMNI 1.6L L4 98
1984-88 : DODGE OMNI 2.2L L4 135
1989-89 : DODGE OMNI 2.2L L4 135
HOPE IT HELPS
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 25, 2010 | 1989 Dodge Omni
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Winter boiler protection
you can turn it down to 55 degrees so that it wil still come on but not freeze, be sure to open the cabinets underneith the sinks so that warm ait will migrate down there to help them from frezing.
Jan 06, 2009 | Honeywell Low Temperature Signal
Home Security Logo
85 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
