Question about Vizio Televison & Video
Vizio model P50hdtv104 no picture but menu and channel display appear on screen
Vizio Model P50hdtv104
    Top Expert:
  • Vizio Master
  • 14,553 Answers
Almost certainly a bad main board---I would also check with Vizio to see if this is a known issue.
The OSD or on screen display being on really narrows this down---Like having a car where the remote will start the engine but the key will not--you know where to look.
Posted on Dec 06, 2012
MNfisherman
  • 11896 Answers
SOURCE: sound and picture interference when changing
It may be the cables you are using. You will need to HDMI cables for high def and rca or coaxil for regular
Posted on May 09, 2009
SOURCE: My Sanyo Vizio can't find any input
press channel up and let it go through channel search, when done- do it again, after second time it should go to inputs
Posted on Sep 12, 2009
  • 4 Answers
SOURCE: 37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Posted on Jan 21, 2010
  • 13 Answers
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
info33
  • 72 Answers
SOURCE: Vizio VO37L LCD will not display picture. Screen
Here is teh quick start guide from Vizio - make sure your set up is correct and the inputs are in the right place. Follow this -
http://www.wigix.com/index.php/skuaccessories/downloadManual/2166516/10708/0/Vizio-LCD-Flat-Panel-TV---37-VO37LFHDTV10A-Quick-Start-Guide.pdf
Posted on Jul 03, 2010
I Have a ViZIO smart TV Model # E420i-Ao Ser# LAQKNRBP0500931 has sound but no picture No light show up in the back and can see any thing on the screen with flash kite when you push channel or menu
It is a common problem for Vizio TV uses a LG 42" & 47" display panel.
The problem is defective back light LED strips, you have to open the entire panel & find the defective strips (it marked as L1, L2 (left), R1, R2 (Right)), the part number usually marked as 6916L-XXXXX.
Both Vizio & LG will not sell the strips, you have to find them on EBay for new or used one.
Jun 01, 2017 | Vizio Televison & Video
Tv channel problem
set your TV! go to menu then click auto search!
Oct 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
I have a Vizio M701d-A3 with single line across the top half of my screen, it appears over top of the menu when displayed. The line is not black but changes color with the picture. What's the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
How do get closed caption Vizio VF550M 55 in. LCD HDTV?
Closed Caption availability may depend on the source. To enable caption viewing, press Menu (on the TV or the remote). Navigate to the Setup menu with the Up/Down arrows on the remote or the Channel Up/Down buttons on the TV. Once Setup is highlighted, press the Menu button again. Repeat the up/down navigation to the CC menu and Menu to select. The first option should be On/Off. Now use the left/right arrows on the remote (or volume up/down buttons on the TV) to choose the desired CC state. Press Menu to save or Last to cancel and return to the previous menu. Press after pressing Menu to return to the previous menu. If your content is from a digital source, you can make adjustments in the appearance of the captions by navigating to those sections of the CC sub-menu. If you would like some idea of what the screen will look like as you navigate the On-Screen Display, see the manual on Page 41. Vizio makes the manual available on their support page. The direct link to the manual is cdn.vizio.com/documents/downloads/hdtv/VF550M/155Manual.pdf . (Note: you'll need Adobe Reader or a similar program to access the manual.)
For some content, you may need to enable the captions at a set-top box (cable/satellite receiver/etc.). In that case, consult the manual for those devices or post a comment with the make/model for additional help.
I hope this helps.
Feb 13, 2015 | Vizio Televison & Video
My Vizio has power, has sound, just no picture. The vizio light does turn blue.
Not sure what model you are talking about, but in general it would be helpful to check the setup menu on the TV. The menu will typically display regardless of the display settings. A factory reset of all the controls may help. (This is in the manual for your model #.) Also check the input cables as well as then input settings in the menu for each input you want to see on the screen.
Jan 15, 2015 | Vizio Televison & Video
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
I am having a problem with my new vizio tv. I am
Try this solution....
1) On the original TV remote press the menu button.
2) Scroll down to SETUP and press MENU button to select it.
3) Scroll down to WIDE
4) Use the LEFT and RIGHT arrow keys to adjust to your viewing preference.
**** NOTE: When you adjust these settings you may notice a difference in the picture on the HD channels. When you are viewing an HD channel but the network is not broadcasting that show in HD they push in the sides to compensate and try to make it a sharper picture but know this is normal.
Good Luck and please rate this solution....
Jan 10, 2010 | Vizio VF550M 55 in. LCD HDTV
Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Jun 20, 2009 | Vizio VX37L Television
Televison & Video Logo
126 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
