Question about Sony CMT-LX20i Micro Hi-Fi System - CMT-LX20i
My Daughters HCD-lx40i wont work without a CD in?
And even then you have to hold the sleep button in whilst pushing the power button to get it out of standby whilst forcing the CD back in as it tries to eject. Then it switches back to standby after a short while. I think its probably a power supply problem of some kind and am quite capable of swapping capacitors etc but im not sure where to start.
Benimur
  • 6966 Answers
SOURCE: Disk Stuck In DVD Machine.
Hi, You need to open the machine or at least the top cover and manually extract the CD. Under the cover and on top of the loading tray is a retaining bar held by 2-4 screws. Removing these would allow you to lift the bar and remove the CD easily. In some models/version, there might be an electronic board partially covering the tray assembly. This type of problem happens when the CD is defective, was not loaded properly, or more than 1 is inside. In some cases, it is the loading mechanism that is at fault. Still in some other models/version there is an access/pin hole below the try at the faceplate where you need to insert a straightened metal paper clip to manually push out the tray. Of course the standard precautions apply, power down, remove from the mains. If you are not comfortable on do-it-yourself, maybe you should seek the services of a qualified professional. good luck and kind regards.
Posted on Aug 26, 2007
  • 169 Answers
SOURCE: Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Posted on Sep 14, 2007
idkia_33
  • 70 Answers
SOURCE: Keeps going to quit screen
it could be that someone pushed the button in too hard and it wont pop back up because even if you lightly touch it, it could go to that screen
Posted on Jan 21, 2008
SOURCE: cd drive won't pull disc into console
Do you have a warranty? If you do, go to the place where you got it and have them check the inside. You may have a broken gear. That could be why it does not take in the disc or eject it. =D
Posted on Mar 25, 2009
pabloloco
  • 2335 Answers
SOURCE: How do I get a stuck disk out of my play station3?
I have seen several suggestions at the playstation*com PS3 forums in the past, such as:
| Zr0_C00L wrote:Try turning it off from the back,
| then hold the eject button while you flip the back
| power switch back on. Worked for my buddies
| when his died (good thing too, it was my game
| in there!)
| i too did the same thing and it worked for me.
This one with multiple discs jammed it sounds like it may apply to you:
"If anyone is having any problems, this is what worked for me. What is more amazing is that my son somehow managed to force 3 discs into that tiny slot...no idea how he pulled that one off.
So after two hours, a pair of tweezers, a fork, and a butterknife, I decided to try one last thing before giving up. I put the PS3 on its nose, disc tray down, held the eject button while it was on, and pushed a disc in and out of the drive. This caused whatever was in there to finally 'catch' as the drive had been trying to force everything out. After 2-3 minutes of play, a disc finally poked out. I pulled what i thought was one and two discs came out. I set it back down flat, tried to put a cheap DVD in (didn't want to test it with a $60 game) and it seemed something was still in there. I hit eject and out came the third disc. I put the DVD in reluctantly and the PS3 took it and loaded it right up. Unbelievable. After all this abuse, it's apparent these things are built like tanks."
You gotta love children.
Hope that helps.
Posted on Oct 15, 2009
My htc 8s wont charge
Do not do a hard reset,you don't need to. Hold the power button down for twenty seconds and the phone will reboot itself.
Jun 13, 2013 | HTC Windows Phone 8S
My sons ipod touch hasnt been used for a couple of months & now it wont turn on or show any signs of charging. i have tried holding the on/off & home buttons without success, please help!
Restarting your device
Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
  1. Press and hold the Sleep/Wake button until the Apple logo appears.
    Follow these steps to reset your device
    Note: Reset your device only if it is no longer responding and the steps above do not work.
  1. Press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
Oct 07, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
WHEN TURN ON PC, GOES STRAIGHT INTO SLEEP MODE. EVEN CLICKING ON F8 DOESN'T PROMPT START OR MENU OPTION. WHAT IS THE SOLUTION?
push and hold power button till all lights turn off.
Then push power button one more time should boot up normally.
Oct 17, 2009 | Computers & Internet
Unit will not turn on
The following suggestions tend to work for most non booting tomtoms
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this.
Sep 06, 2009 | Tomtom ONE GPS Receiver
Black screen only
try to hold power button, until shutdown. Remove battery. Connect power cord and try to boot again.
Apr 14, 2009 | Dell Latitude C640 Notebook
Accidentaly pushed the hibernation button on my gateway GT 5408
Hold the power button for 3 seconds until it turns off... hopefully this doesn't mess XP up...
Dec 18, 2008 | Gateway (2900147) PC Desktop
Not returning to 100%
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
Jul 09, 2008 | Bionaire BAP1300 Air Purifier
Sony CMT-LX20i Micro Hi-Fi System - CMT-LX20i Logo
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
