Question about Sharp AR-M350N Copier
SHARP AR-M350N error code L4-02.
"CALL FOR SERVICE L4-02 ERROR CODE" IT'S DRIVING MY CRAZY
  • 61 Answers
SOURCE: Sharp AR-M350N/H5-01
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Posted on Jan 25, 2008
  • 120 Answers
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
  • 126 Answers
SOURCE: Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Posted on Jan 28, 2009
007tech
  • 95 Answers
SOURCE: Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
  • 87 Answers
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Posted on May 09, 2009
MY AR-M350N COPIER DISPLAYS F1-15 ERROR CODE, IT ALSO SAYS THAT THE FINISHER IS OUT OF SERVICE. PLEASE I NEED A SOLUTION TO THIS PROBLEM
The error code F1-15 means that the stapler is not in home postion. It can also, be that the exit tray is not in "HP" aswell. I would turn the copier off and turn it back on and not use the stapler funcation. To repair the problem, there are a bunch of up dates to resolve this problem. I would change the out put tray from the finisher to the left out put tray... Good Luck
Mar 17, 2012 | Sharp AR-M350N Copier
Code erreur E7 03 SHARP AR-M350N
E7-03 means that the machines hard drive has gone bad. It can be backed up and replaced by a trained copier technician.
May 22, 2011 | Sharp AR-M350N Copier
Code U2-91 on Sharp AR-M350N
Try to reset this by #*C* and press 16 press start, if this not resolves your problem theEEPROM is defective , Replace EEPROM on the MCU PWB.
Apr 13, 2011 | Sharp AR-M350N Copier
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
Sharp AR-M350N memory?
AR-M350N may be have 16 Mbyte of internal memory.
You could expand it until 256 Megabyte.
I attacched to this post an image that describe compatible expand memory.
Nov 03, 2009 | Sharp AR-5320 Black and White Copier
Error code H5-01
HI.H5-01
check its cable
reset this code
press ,p,*,clear,*
May 07, 2009 | Sharp AR-M350U Copier
Code: H4-00, H4-0Q
Jan 25, 2009 | Sharp AR-M350N Copier
Sharp AR-M350N Copier Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
