Question about Panasonic Lumix DMC-FX9 Digital Camera
Zoom causes camera to shut down automatically
I used this camera for a couple months, everything was grand until suddenly the zoom started giving me stress. I can zoom in a teeny bit, but as soon as I zoom in too much, the lens retracts and closes, and a message tells me to turn off the camera and turn it back on. I do that but it doesn't solve the problem. As soon as I try the zoom, it does the same thing. I've tried taking out the battery and putting it back in but nothing seems to fix it. Any ideas??
    Novelist:
  • 198 Answers
Unfortunately this is a well known problem with digital cameras. And in most cases this doesn't end up pretty well. Your camera contains a lot of servomotors and small lens and sensors. They work togheter in order to produce sharp pictures and expose the main CCD sensor to correct amount of light. When you start the camera, it's main circuit board, wich contains it's microcontroller (some kind of a camera processor) will run some tests to see if the lens assembly works correctly and if there isn't anything that can block the lens extension procedure. If this test fails you will be given a message telling you to turn the camera off and back on. Your camera obviously passed this test since you can take pictures. However the camera can't test the zoom function at the begining because this is done by using zoom motors and the ccd sensor at the same time. The sensor isn't turned on at the initial stage when the test it's made. When you try to zoom with your camera, in your case, the speed on wich the lens are moved back and forth doesn't correspond to the speed value stored in the camera's microcontroller and used for calibrating the ccd sensor. The camera will inevitabily give you this message as it thinks that this is a small problem with the lens and because of a shock received, the lens alligment got messed up. It thinks a reset will do the job, as when it retracts the lens back they will come again up with the correct settings. In your case the most probable thing that's rong inside your camera is a small servomotor that has the function to extend the distance between two lens in order to "zoom". The 2 lens are contained in separate mooving parts of the lens assembly, and those parts moove apart one from each other by sliding on some small channels. If this becomes altered or decalibrated, the movement of the motor woun't produce an acurate movement of the lens. These are very fragile components on any camera so they can get out of balance from all sort of reasons. Maybe a mechanical shock, maybe something inside got loose or change it's possition, there are many reasons. In order to fix this, the camera needs to be dissasembled and the lens unit should also be opened. You will need very delicate tools and it's recomandable to work in a dust free environment. If you aren't the electronic/mechanic type of person I strongly recomand that this operation should be performed in a camera service center. That's because if you damage or decalibrate something inside the lens assembly, the whole mechanism will need to be changed as it's imposible to repair in most cases. In your current situation, a repair can be done and shouldn't be that expensive. If you however for whatever reasons decide you want to try fix the camera yourself (I, again state that this involves pretty much risks) you may reply to this and I will try to guide you throught. I'm sorry, however, for I am the one who delivers the bad news about your camera. This is a hard to do repair, most specially in a DIY fashion. Good luck and please feel free to reply if you need more informations.
Posted on Jun 09, 2007
My camera worked fine for 3 years, when suddenly .... when i'm zooming fast (zoom button pushed down) camera switches of. If i'm zooming slowly everything is ok. Some master said that zoom lens motor...
I would say to check the batteries and their connecting surfaces plus the contacts in the battery compartment. With bad connections on the batteries, when the camera zooms slowly it does not use much power. When zooming fast it uses more power (current) and if the batteries are making a poor contact the camera will shut down due to low volts. Check that first before spending big money. If you are using Duracell batteries, they have a short + pip end which some devices will not work with them due to poor conection. Compair a duracell battery with another brand. see the difference on the + end.
Aug 04, 2010 | Canon PowerShot S3 IS Digital Camera
Turns on then shuts down automatically
As long as the battery is fine - try taking out the memory card and turning it on maybe? Sorry, but the lens are probably broken. Does it give an error message?
May 15, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Zoom out and it shuts down
Don't think you'll have to send it in for repair. How old is your battery? Keep in mind that it isn't meant to last for more than a year or two, regardless of how often it is used. A camera will automatically shut down if its battery power is getting low. This usually occurs when the camera is doing power intensive actions, such as zooming (it uses a motor). Anyways, Amazon has some generic options for you if your battery may be over-the-hill:
http://www.amazon.com/s/ref=nb_ss_p?url=search-alias%3Dphoto&field-keywords=kodak+m1033+battery
Jun 06, 2009 | Kodak EasyShare M1033 Digital Camera
Have used the camera successfully for the past 9 months, up until Friday no problems. Then all of a sudden camera just shut down, while in use. I've re-charged the battery several times longest period of...
maybe you droped it in water or on the floor. have you tryed changing the battery at all? if so you should take it back to the shop they got it from and explain it to them. they should give you your money back or give you a new one!!
Apr 13, 2009 | Cameras
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
My Acer Lappy turns off automatically!
This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
Jan 11, 2008 | Acer Aspire 5630 Notebook
Sony DSC-S650 ( 7.2 MP and 3x zoom) - Not working
I have the same camera and have had the same problem. The first time I had to change batteries I could not find lithium batteries and ended up trying alkaline batteries. I was only able to take 1 or 2 pictures before they would die and the camera would shut down. When I switched back to lithium batteries, everything worked fine. I hope this helps.
Dec 30, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Panasonic Lumix DMC-FX9 Digital Camera Logo
140 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
