Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
My ge profile ice machine on off light is blinking and not making
My ice machine is not producing any ice on/off light is blinking replaced filter a couple of weeks ago
  • 1,543 Answers
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Posted on Jan 12, 2009
Why is my ice maker not working?
Just replace icemaker. Type "im6 icemaker " in eBay or Amazon
Aug 17, 2014 | GE Profile PSW26P Stainless Steel Side by...
Why is the orange light on , what does the orange light mean?
If the bin is full there is a light that stays on. If it is time for a cleaning, there is a light that stays on until reset.
Jan 15, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
284 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
