Any button I push,"Hold"appears on the display.. Can't do any action
    Problem Solver:
  • 19 Answers
Had one that use to do that , it was under warranty so sent it back and they changed some minor chip that wasn't working, warranty ran out got a new similar fault so brought a new one. Sorry couldn't be of more help
Posted on Dec 06, 2012
Resetting service indicator
1) Make sure ignition is off
2) push & hold in left button (daytrip reset)
3) while holding in, turn ignition key into pos.1
4) keep holding button pushed in while "Test 1" appears in display
5) after a further approx. 5 seconds oil service inspection will appear (whichever is due)
6) release button when oil service/inspection are displayed
7) pushing and holding in the button for appr. 5 secs will reset the service interval
8) release button and switch off ignition. When restarting interval should be reset
hope this works.
Sep 07, 2014 | 2014 BMW X1
Unlocking gateway theft deterrent
go to the dealer
  1. Turn ON the ignition, with the engine OFF.
  2. Turn ON the radio.
Does the radio display LOC?
Is the security code known?
  2. Press and hold the radio preset buttons 2 and 3 for approximately 8 seconds until the first 3 digits of the backup code are displayed on the radio.
  3. Record the displayed code.
  4. Press and hold the AM/FM push button until the second 3 digits are displayed on the radio.
  5. Record the displayed code.
Could you successfully extract the code?
Contact Delco Electronics in order to give them the backup code information and to obtain an unlock code.
Did you complete the action?
Important:: If 8 unsuccessful tries are made to unlock the radio, the display will return to the LOC display, but when the SET button is pressed, INOP will be displayed. This means that the radio must be left powered up for 1 hour with the battery and the ignition applied before any more attempts to unlock the radio can be made. Anytime INOP is displayed, 3 more attempts will be allowed after the 1 hour waiting period with the battery and ignition applied.
  1. Ensure that the code to be used is correct.
  2. Turn ON the ignition, with the engine OFF.
  3. Press the MN button until 000 is displayed.
  4. Press and hold the HR button until the first 2 digits agree with the code.
  5. Press and hold the MN button until the last 2 digits agree with the code.
  6. Press the AM/FM button when the complete code is displayed. If REP appears on the display, repeat this step.
Did you successfully complete the action?
Replace the radio. Refer to Radio Replacement.
Did you complete the replacement?
Operate the system in order to verify the repair.
Did you complete the repair?
Apr 03, 2014 | 2001 Chevrolet S-10
Set clock on 2004 Rendezvous
push and hold the H button four the hours to change and push and hold the M button to change the minutes. You just have to hold them in until the numbers change.
Mar 09, 2014 | 2004 Buick Rendezvous
What does daignostic code dia9 mean?
The IM (instrument module) is capableicon1.png of
displaying DTC's (diagnostic trouble codes).
1- Ignition off
2- push odometer reset
button in & hold. Make sure run switch is on.
3- turn
ignition to run and release button (you will see P, S &C displayed)
4- each letter represents an area of diagnostics... the one that
is flashing is the one you are going to check. To move from one letter to the
next, you push the button one time. (from P to S to C and back to P, etc.)
5- to get DTC within an area, you push and hold the button in
for 5 seconds and if there are any, it will be displayed... you can release the
button. As you push the button again, other codes will appear if they are there.
If there are not any the wordicon1.png 'none'
appears.
6- Record the codes.
7- To
determine if a code is current or historic, you clear the codes while being
displayed by pushing in and holding the button until 'clear' comes up. Turn off
the ignition... then crank or restart the bikeicon1.png... turn
off, and then repeat the code process. If a code is there now, its current... if
not, it was historic.
Codes
Aug 16, 2013 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Fault 9 come on
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
How do you reset the computer after an oil change?
get in the car close the door turn the ignition on but dont start the car. wait intil the clock is displayed in the instrument cluster or push the bc button to display it. next press and hold the button on the left of the instrument cluster. an orange triangle will appear keep holding button in. next the cbs service data will appear release button. by pushing button briefly without holding you can scroll through service data. when an oil can is displayed press and hold button again. the word reset with a question mark will be displayed. release and press and hold button again oil service will reset
Jan 05, 2011 | 2006 BMW 5 Series
How do you reset the service engine light on a 2006 525i
In 2006 BMW developed what they Condition Based Service (CBS), this means even when you change the oil and filter, the only way to reset the service indicator is to take it to the dealer, to be hooked up to thier computer. I have the same problem, I am waiting for some aftermaket code breaker to be developed to fix this problem. Hope this helps, let me know.
Aug 09, 2010 | 2006 BMW 5 Series
My 2006 C280 was due for service B , and I just did the oil change only. How can I reset service B message on the car computer ?
Reset process should be listed in the owners manual.
Should be something like turn car to on(not running) press trip button twice, turn to off and hold trip button till it resets.
Apr 19, 2010 | 2007 Mercedes-Benz ML320 CDI
My Action Replay appears to have lost all codes however it will not allow me to resave any new codes to it. It says operation failed, not enough space. It should have plenty of space as all codes have been...
You can fix the device just hold a+b then turn on the ds still holding a+b when it says this product is not endorsed by nintendo just hold start and select now you are holding 4 buttons continue to hold these buttons until the main action replay screen its displayed,then release.Now connect the action replay to your computer and now it will accept every code you want.I hope this was useful for you.
Sep 04, 2009 | Datel Action Replay for Nintendo DS
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
