Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
  • Anonymous Mar 27, 2014
    CD drawer won't open
  • Audio Player... Master
  • 1,267 Answers
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Posted on Dec 11, 2012
  • Joseph Pham Dec 12, 2012
    Thanks for your help. I will bring it to a local service shop.
  • 112 Answers
SOURCE: harman kardon CDR 26 cd recorder
It's the belt from the spindle motor to the gear. It's worn and can't grip the spindle anymore. If you elp it to start off it works. Open the unit, remove the cd tray and it's underneath at the front. You can replace with a similar size elastic band.
Posted on Jan 15, 2008
  • 112 Answers
SOURCE: HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Posted on Mar 10, 2008
  • 1257 Answers
SOURCE: cdr tray/door won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Posted on May 02, 2008
SOURCE: Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Posted on Jun 17, 2008
  • 3 Answers
SOURCE: Problem with Tascam Cd-RW750. system error at
hello ,, how can i find optical pickup for TASCAM CD-RW 750 RECORDER ,,, what is the number of this optical please somebody help me ,, thanks ,ferr
Posted on Sep 27, 2009
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Cd recorder won't read blank cd
If it is a older CD Recorder, You have to use disc,s that stay music on the label. Disc,s for burning music from a computer will not work in them,
Dec 04, 2012 | Tascam CC-222mkIII CD Player / Recorder
CD Player Tray keeps opening and closing by it self
This is either caused by the drive belt slipping, the closed sensor being faulty or an obstruction to the tray.
Basically the tray isn't makeing it to or registering as being in the fully closed position.
May 02, 2011 | Tascam CC-222mkIII CD Player / Recorder
I have a Harman Kardon CDR2 and the cd drawers will not open. Do you know how to fix this?
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Feb 13, 2011 | Harman Kardon CDR2 2-Disc CD Recorder
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Problem with Tascam Cd-RW750. system error at start up after the "welcome". Then it opens the cd tray and does nothing else.
Jun 07, 2009 | Tascam CD-RW750 CD Recorder
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Harman kardon CDR 26 cd recorder
Nov 14, 2007 | Harman Kardon CDR2 2-Disc CD Recorder
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
251 people viewed this question
 Grubhead
Grubhead
