Question about Gigabyte Computers & Internet
No video signal no beeps - Gigabyte Computers & Internet
  • 3,799 Answers
Check your RAM is good. This is a normal symptom for RAM failure. As long as the fans are running.
Posted on Dec 06, 2012
  • brandon Dec 06, 2012
    that did not work the memory is good. I checked the i tried with one stick and still the same result. i have checked the video card and it is new and the same thing happens with another card. the motherboard is new and have stared i hear no beep codes. i also checked the wire the only thing not new in the computer is the power supply and the processor
Diagnostic beeps
try google on motherboard error beeps good article and see if you can match up the beep pattern. it says 2 short one long for video problem. good luck
May 23, 2010 | E-Machines eMachines Desktop PC
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
What does 4 beeps mean on startup?
here is a link to all the beep codes this should help you
http://www.computerhope.com/beep.htm
hope that is ok
Feb 10, 2010 | Compaq Computers & Internet
When I power up my T5086 RA, I get three beeps and no video signal at all, even with a PCI-E video card. Help!!!
Sounds like memory problem.
Remove the memory modules and then insert one, and try to reboot. Do this until you find the faulty memory.
Don't forget to rate this answer if it helps
Dec 24, 2009 | Computers & Internet
NO VIDEO SIGNAL NO BEEPS ONLY CPU FAN WORKING
Please verify that you have a good processor. It seems that your processor is bad.
Oct 31, 2009 | Gigabyte GA-K8VT800 Motherboard
My system is stating that there is no signal but the PS3 is plug into an HDMI cable and the signal is fine. I switched the HDMI cables from the TV to the PS3 and the signal is good. How do I correct this?
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Just beeping
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Oct 24, 2008 | Gateway GT5654 Desktop PC
No video signal
Try turning the console off, then holding down the on button until you hear a series of beeps, each beep representing the system switching video modes. (try testing another output source to make sure your tv is working correctly) if your tv accepts other video signals then you should find the correct one from your ps3 with this method. you may have to get it to work on AV or S-Video to make the appropriate changes to the HDMI and set the proper resolution for your television first.
Hope this helps.
Mar 31, 2008 | Sony Playstation 3 (PS3) Console
No signal on monitor
The beeps you heard, 1 long two short is the bios telling you that there is a problem with your video card. Normally you would remove & reseat it. Not the case with the intergrated video. When you added an AGP card you should have been able to get video. All video is controlled by the intergrated video controller. If your sure the radeon works than all that is left is the mb controller which can't be fixed. There is a slim chance you might get a PCI video card to work. Link to your board:
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1766
Jan 13, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Open Questions:
Computers & Internet Logo
52 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
