Oki mc160n error message machine trouble service call (001B)
It just initialiaee then had grind noise as if gears a not pulling
flopez
  • 161 Answers
SOURCE: Oki C5150N Grinding noise
One of the drum cartridges is stuck. Test by removing them one at a time with the printer off, then turning on.
Posted on Nov 02, 2007
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
  • 13433 Answers
SOURCE: Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 11, 2009
taminol
  • 62 Answers
SOURCE: my brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Posted on Apr 26, 2010
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Posted on May 11, 2010
How do i remove toner manually in a a oki mc160. I am getting a service call 001b error
Error 001b means the dev motor cannot turn. The most common problem on this extremely complicated system is that a toner has not been locked correctly and has come loose thus jamming the drum and preventing it from turning. The easiest way to resolve this is to remove the front cover which will give access to the drum mechanism. You hopefully may be able to then push the unlocked toner back into place. This type of printer is a pain when it goes wrong. Have not seen one in years even though only came out in 2009. Good luck.
Mar 09, 2017 | OKI Office Equipment & Supplies
CALL SERVICE (0500) what does it mean ? how to solve it ?
The users manual says when you get this error to reboot machine and if the error doesn't go away the problem can only be fixed by an authorized service provider.
Dec 28, 2012 | NEC Oki Mc160N A4 Colour Multifunction...
Error code 001B
I have a toner bar out and cannot get it back in and the 001B code came up... any ideas on where I can go with this now?
Feb 24, 2012 | OKI B Office Equipment & Supplies
Hi,, i have an oki MC160n,, that has an error coming up after a couple of pages being printed.. it says "paper size error, reset paper (1lt) press start key" can you help me fix this please
Please check the settings in your printer that you have selected correct paper type and tray from which you are printing. Also while giving print command make sure paper size is same.
May 05, 2011 | OKI Office Equipment & Supplies
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
please try this
alternative :
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
OKI C5100 Making grinding noises
Click the following link, it should solve your problem
http://www.fixya.com/support/t238726-sensor_error
Regards Wayne
Aug 05, 2008 | OKI C5100n Laser Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
980: Fatal Error
*Service call
980:Error
*Error by media
*Power OFF
Suggestion -
Apr 07, 2008 | OKI C5800Ldn Led Printer
1,750 people viewed this question
k24674
jasbo
jasbo
