Question about Mantis 2-Cycle Tiller
What are the card settings on troy bilt 2 cycle mini tiller
Will not idle or stay running when it does it want run smooth has low hours on it i put a new carb kit in it but dont know the setting on fuel mixtuer screw
  • 48 Answers
SOURCE: My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Posted on Oct 17, 2008
  • 376 Answers
SOURCE: difficulty adjusting carb for smooth idle and full power tilling
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
Posted on May 13, 2009
  • 15 Answers
SOURCE: Won't stay running...
I had the same problem with my mantis. It would start fine after a few pulls, but had no power. I changed the plug, replaced the carb completely...nothing helped. Took it to a shop and paid $70 for a tune up that didn't help at all, and the shop owner just said "sorry".
After everything else was done, I pulled the cover off the muffler, (3 screws) then removed 3 screws over a small spark arrestor screen and found it was clogged...cleaned it and guess what...IT WORKS FINE NOW!
The best and easiest fix I have ever done to a small engine. I felt like an idiot, because the exhaust side of the motor MUST be clear to work properly on small engines. The only reason I was removing the muffler in the first place was to check the compression and VOILA!!!
An easy and quick fix I recommend for all Mantis tillers before you waste money on carb issues (which is what the company will tell you to fix to solve this problem).
Posted on Jun 03, 2009
Dusterz
  • 46 Answers
SOURCE: Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Posted on Jun 06, 2010
daneinwv
  • 124 Answers
SOURCE: My Mantis tiller is 9 or 10 years old. I've
My name is Dane and I am going to assist you in solving your problem.
You should have an idle screw adjustment on the carb to adjust the idle RPM. As you pull the trigger, watch on the carburetor for a small moving plate. The idle screw should touch that plate. Be very careful, and have someone hold the tiller and start it. Back off the screw just enough until the tines stop turning. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I've deserved them. Thank you! Dane
Posted on Dec 06, 2010
I am having a hard time getting my carburetor adjusted for my Troy Bilt 2 cycle tiller
First you need to repair the fuel inlet properly. You likely have an air leak the way it is now. You can get a replacement inlet elbow at your local parts shop. Tecumpseh and briggs are a bit different but look very similar so be sure what you have before you go. grab hold of the brass with channel locks or vice grips and pull straight out to remove the old one. Put a dab of oil on the new one, align the way you want it to face and press in firmly. Do not twist or it will break again.
Once the inlet is repaired properly then you can adjust the carb. The low speed jet is the one closest to the motor. The initial settings are 1 and a half turns out for both low and high.
Sep 19, 2012 | Troy-Bilt Garden
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Troy bilt bronco model # 12180starts & idles fine. How do you set or fixthe governor . It runs at idle speed all the time. I can force the governor open and it with run fine until I turn loose of the...
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
Mar 25, 2010 | Troy-Bilt Pony Garden Tiller
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Which small ''mini'' tiller to purchase
Definitely stay away from Ryobi, Troy Bilt, Bolens and Yard Machines by MTD. They are all Ryobi with different brand names on them. (goes for trimmers too) MTD owns them all. The best small tiller, IMHO, is Mantis. (2-cycle) I think Sears sells them now. I have one and it will run circles around the rest.
Jun 14, 2009 | Ardisam Inc Earthquake Mini Cultivator
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mantis 2-Cycle Tiller Logo
264 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
