Question about Acer Aspire 4720 Notebook
Network issues with my acer laptop
Ip addresses keep dispearing when ever i shutdown on restarting i have to go through the process of assigning ip addresses again .i connect wirelessly to a network , the laptop is just about 3weeks old
  • a_oyedeji Jan 15, 2009
    actually, i didnt get the solution to what i needed the sites really helped in some other aspects
    what i really wanted was a solution to network issues on my accer system cos when ever the router goes off the ip addresses of the systems disapears i now have to re-entered the ip 's again but if you shut down the system before the router goes off the ip addresses remain
    and i bought 10 of these acer system in question someone kindly please help me out.
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Alficio mp 5001
Printer must be totally shutdown and restarted after assigning new IP address.
May 05, 2014 | Computers & Internet
I've powered my 9620 off/on, moved the phone to a different desk. I keep getting DHCP Conflict and the phone keeps rebooting. I am not able to CRAFT... does not work on this phone at this point.
Someone configured a static IP on your network. The DHCP server thinks that IP is free and keeps handing it out to you. You can either trace the equipment (workstation or phone) that has that IP or you can go into the CRAFT menu and assign a static to the equipment (please check with your network or system administrator to see what IP you can assign to your phone. Also talk to your network admin if you are using VLANs)
To get into the craft menu and change the ip address settings
1. during the startup of the phone press the * key when you see "* to Program" during initialization
2. enter 27238#
3. navigate to the ADDR menu
4. change the ip address, call server ip, subnet, router to the correct ip addresses
5. if needed change the http, https, or file server address
6. restart phone
Mar 08, 2011 | Avaya 9620 IP Phone
Window system error: there is an IP address conflict with another system on network?
The router to which you are connected is badly configured so th same IP has been issued to another pc. Either configure the router to assign the addresses in its network dynamically or manually assign yourself different addresses to every pc.
Jul 24, 2010 | Dell Inspiron™ 600M PC Notebook
Can not get wireless connection on asus notebook
Try resetting the network adapter.
On the bottom right hand side of the desktop you will see the wireless icon, right click on that ans click on troubleshoot problems. This will reset the adapter and assign an IP address for your your PC.
When its done try to connect to the internet.
If this advice does not help please post back.
Good luck.
Jan 11, 2010 | ASUS m6n Notebook
Netgear wirless and acer laptop/ lapt. not seeing mac address/net
Probably your adapter has one ip fixed address.
Check on the network, your ip adapter settings and be sure that the option "obtain the ip address automatically" is selected.
Go to -->> Control Panel --->> Network Connections --->> Select your connection and go to properties --->> in the center field Select internet protocol TCP/IP---then hit--Properties---Go to General and set your connection as automatically there.
Jan 23, 2009 | NetGear WGR614 Wireless Router
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Linksys WRT54G Router with ethernet connection & wireless. Has been working perfectly for ages with a wireless laptop & Samsung i600 phone. whether coincidence or not a few days ago I logged someone else's...
looks like the new laptop has been assigned the same ip address as your old latop so it wont allow u access...renew the ip address, assign ur old lap top a new one or just reboot the router so it will issue u with a new ip address.
Feb 15, 2008 | Linksys Wireless-G WRT54G Router
Manually assigned IP setting lost
see there are two types of connection in your laptop pls see u define on which network choose local lan and assign ip adress and save .
Dec 17, 2007 | Computers & Internet
Acer Aspire 4720 Notebook Logo
42 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
