Question about Panasonic Heating & Cooling
I have a CS-E24FKR Air Conditioner,, Timer light constantly on ,,Blinking 60 blinks per min Turn Power off at Supply.Turnback on Remote w2orks allOperation details.. Shuts down aftewr 8 minutes runnin
Timer light on and blinking. Unable to operate Unit with remote.. Checked batteries. (OK)Followed Manual..Set time on Remote Set Mode to Auto, The Air Conditioner works for approx 8 minutes after the C/B is turned off then back on.. Timer light comes back on blinking. Not able to get response with remote i.e. Timer has stopped all responses.
  • 3 Answers
SOURCE: i've got a pana inverter
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Posted on Jun 11, 2008
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
Hi, I had exactly the same problem.  You need to keep pressing the middle "up" button until you reach the number of the error and then it will beep.
My error is number 15, I have to contact the repairer to see what it means. Hope this helps.
Posted on Aug 26, 2009
  • 289 Answers
SOURCE: Hoffwell Air Conditioner KFR 61GW turned itself off
You may want to check the thermocouple. It should be located on the front coil. You have to remove the front cover to see it. However, close the vents and try it. If is overly humid that front coil will just condense all available outside humidity and the thermostat will be frozen. Pull the thermo stat away from the coil so it is not being frozen. Replace TC after that test Good luck.
Ash
Posted on Dec 08, 2009
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
My Panasonic air conditioner model is A75C3012 when i turn it on it start 2or 3 minutes after that the timer light is blinking it turn off by itself. how can I fix this? Thank in advance
Try this and see if it works:
- check the remote and set the timer ioff;
- while is turned on, unplug the unit for 5 mins.
Hope it helps.
Regards,
Dan
Oct 19, 2016 | Panasonic Heating & Cooling
Panasonic CS-E24FKR Airconditioner keeps turning off. Error code 15 H
Is the air-conditioner plugged into an extention cord or directly into the wall outlet???
Aug 20, 2016 | Panasonic Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
My panasonic airconditioner c9kkzw timer is always blinking and automatically turned off every hour. its driving me crazy becasue my kids won't asleep.. please please help me, tried turn and off but to no...
I think, you have set the timer for one hour. No problem, remove battery from remote and reset it and same way isolate the power to your air conditioner for 5 seconds and reset it. Now all pre programmed would have been canceled. Now you can set your temp as you like.
And another reason may be your compressor getting heated after an hour, due to dust blocked in your out door coil. Hence, please serive the unit at once. Thanks.
Dec 15, 2010 | Panasonic CS-A12C Air Conditioner
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
This is a sign of a bad board. They are cheap and easy to replace. They will need to be replaced or you will continue to have this problem for as long as you own the unit
Jun 03, 2009 | Panasonic CW-1006FU Air Conditioner
FUJITSU SPLIT AIR REMOTE CONTROL PROBLEM
I had a similar problem with only fan air then the blinking lights, found out that mice had got into the circuit board and corroded some connections with their urine. I would try the above solution by turning the power off for ten sec first but remember that you have to leave it for a few minutes before you operate remote.
Aug 25, 2008 | Fujitsu 24C1 Air Conditioner
Jun 03, 2008 | Heating & Cooling
Heating & Cooling Logo
214 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
