Problem with Rangemaster Classic 110 Kitchen Range
how to replace hob plate on electric rangemaster 110
Rapid hob plate (front right) is not so rapid anymore. Where is access to remove old plate and replace with new? I assume it is at the back but would apprciate advice before |I pull out the range and start dismantling it!
Posted by avatar on Jan 12, 2009
    • By avatarMagnamus Jan 18, 2009
    • I have the same problem.
      Electric Rangemaster Class 110, only a year old, but the front-right hob plate gets warm but not hot.
      Any tips would be greatly appreciated.
Suggested Solution (3)
it is not at all obvious.
from memory, there are 2 screws on the lhs side of the plate which remove and the plate will then move sideways but may be difficult to shift
  • by Author image douglas smith Over a year ago
Source: rangemaster 110
Was this solution helpful?
No
Yes
the ffd comes has a unit with a gas tap connected to it. can be brought for £90.99 from manufactures.
  • by Author image gasandair Over a year ago
Source: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
No
Yes
Hi, a complete shot in the dark as its a while since you posted - we have a mains gas rangemaster 110 and need an LPG one, do you still need to change or have you sorted it now? Cheers
  • by Author image danmonza Over a year ago
Source: I have a rangemaster 110 LPG Hob and double oven
No
Yes
Tips for Helping tonyeileen_s With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all Rangemaster Classic 110 Kitchen Range Problems
