Question about Linksys WIRELESS-G WRT54GS 802.11G WIRELESS BROADBAND ROUTER W/SPEEDBOOSTER (LK54GS)
Change lynksys wrt4gs router from strict to open easily
I am really wanting to know how to change my router settings to open from strict to play multiplayer on my xbox and psp vita any help would be greatly appreciated and where to start or any links ty PLEASE HELP!!!!
  • 2,878 Answers
  • 11 Answers
SOURCE: Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Posted on Jul 18, 2008
2Gigs
  • 141 Answers
Have you called linksys regarding this problem? Try this http://technicalsupport.blog.friendster.com
Posted on Feb 15, 2009
Go to your router admin panel and into advanced settings and set UPnP (Universal Plug'n'Play) to enable. If that doesn't work then manuallyopen the ports on the IP assigned to your Xbox. Opening NAT all the way is never a good thing. it opens you up for attacks. So with the above mentioned solution, either way, you should game on well!! Go forth and frag!!
Posted on Apr 12, 2009
Joed911
  • 4338 Answers
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
stif_NEC
  • 441 Answers
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Posted on May 07, 2010
The router was open two days ago when I was playing the xboxlive suddenly the next day it changed to strict how can I change it back to open so I can play with my friends online?
Basically what happend is NAT closed instead of being open NAT. You have to log in to the router ip address in your web browser and set it to open nat. You get your router ip address by going to the command prompt and typing ipconfig. You can google this procedure or consult Netgear as they can walk you through it easily. Youtube has videos on how to open Nat on many different brand of routers. Now you know the problem and what the answer is please rate and comment!!! Thanks.
Dec 22, 2010 | NetGear WGR614 Wireless Router
How to change the nat settings on my belkin play router from strict to open so i can play the ps3 online gameplay more easily.
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
Jul 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
Look through the menu's on the router for UPNP. Turn it on. Then turn it on on the XBOX. UPNP is Universal Plugand play. that should configure the router for you automatically.
Dec 05, 2008 | Zyxel P660HW-D1 Router
NAT settings are set to Strict
Go to this link this will help you with your problem.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Once your on this page select the model of your router (look into Netgear).
On the next page select XBOX live. After this, this will give you instruction how to open ports for your xbox live.
Aug 04, 2008 | NetGear WGT624 Wireless Router
Strict nat settings
go to security tab on the router interface and deselect NAT button.
Jul 03, 2008 | NetGear WGT624 Wireless Router
Change NAT to open
Click apply.
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
Computers & Internet Logo
51 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
