Question about Harman Kardon AVR 300 Receiver
Harmon Kardon AVR300 center speaker channel has distortion. Have replaced the center channel speaker and cables. Still have distortion. No other distortion in the remaining speakers or s/w.
This condition started about a year ago. I thought the center channel speaker was damaged due to it being dropped. I replaced with a new Infinity PC250 and the distortion still exists. I connected the old Klipsch center speaker to another receiver and there is no distortion. The problem appears to be with the HK AVR300.
SOURCE: cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Posted on Jun 10, 2008
SOURCE: Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Posted on Dec 24, 2008
Tekmekanik
  • 34 Answers
SOURCE: static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Posted on Jan 29, 2009
  • 4234 Answers
SOURCE: Harmon Kardon AVR300.**protect** blinks when
The protect message means that the outputs are shorted. This is a fairly common problem that can easily be fixed by any shop that handles audio gear. Expect a parts cost in the $20-$40 range.
Dan
Posted on Mar 17, 2009
lock123
  • 6831 Answers
SOURCE: I have an AVR 335 less than 3 years old no sound
Hello
Yes, there is something you can try, to know where to look for the problem if this happens again. If the receiver is still under warranty, just send it back, otherwise, open up the amp and trace the path back from the speaker channel to the capacitors on each channel, this is usually the problem(you should be able to see if it is blown, cheap to repair).
If all the channels went out at the same time, there is something wrong with the central unit, to repair that, if it is not the above problem, cost expensive.
Hope this can help you.
Kind regards
Andrea
Posted on Nov 09, 2009
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
Distortion with HK AVR 144
This sounds like the amplifer is playing up. If the distortion is on more than one channel, you are looking at a faulty part common to both channels. If on one channel only, perhaps something in the pre-amp or power amp sections. Have a look inside, you might find a burnt resistor, which would cause it.
Dec 21, 2009 | Audio Players & Recorders
Harmon Kardon AVR300.**protect** blinks when powered on.Took cover off no obvious problem.Disconnected EVERYTHING from back panel,still blinks **PROTECT**.
Dan
Mar 16, 2009 | Harman Kardon AVR 300 Receiver
Lost the power cable from subwoofer of my harmon Kardon
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
Mar 05, 2009 | Harman Kardon SoundSticks Computer...
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Center Speaker sound just not right
If the optical cable was bad, the sound would be distorted period. The optical cable (whether coax or fiber) just simply carries the coded audio to the receiver which in turn decodes it. I have never heard of a signal just screwing up the center channel, and I've been at this better than 30 years. Not to say it's impossible, but very unlikely.
Did you try swapping speakers? Move the left one to the center and the center to the left. Does the center remain "distorted"? Does the left become "distorted"? If the center remains distorted, the receiver's center channel has something wrong with it. If the left is distorted, the speaker has a problem.
For the future. it is un-neceaasy to purchase expensive cables. In fact it could make things worse. The claim to fame of most expensive cable manufacturers is the gold plating on the connectors. Unless the bioth sides have gold plating (receiver, cable box) this actually creates a capacitive reactance between the different metal types. FYI-capacitive and inductive capacitances are the basis for designeing cross-overs, filters, etc. So basically, an undesired filtering effect is created. This applies to speaker cables, audio, video, etc....
Jeff
Feb 15, 2008 | Harman Kardon AVR 635 Receiver
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
Harmon Speaker distortion
Hi, I came across a similar problem with an old Altec and the the solution was to only replace the defective side. Actually, what was replaced was only the speaker itself inside the enclosure which was cheaper rather than replacing the entire assembly. An electronics technician (not necessarily a computer tech) can do the job since some soldering might be involved.
Dec 02, 2006 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon AVR 300 Receiver Logo
60 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
