My monitor's display blacked-out!! Need to fix it
  • 1,684 Answers
What brand and model monitor do you have? We need additional information to be able to provide the correct answers to your questions.
BuddyMc
Posted on Dec 07, 2012
3 Suggested Answers
SOURCE: my lt865b doesn't display anything and the display
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 07, 2010
budmrtn
  • 11361 Answers
SOURCE: My monitor stops showing anything every 1 or 2
Look for bad caps in the power supply first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 05, 2011
The buttons on my monitor are broken and I am getting a black line!
You have not mentioned your graphic card ,anyways chage the resolution of your display so it might fit in somewhere without overlapping
Apr 05, 2013 | Dell E171FP 17" Flat Panel LCD Monitor
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
What's your problem?Need help to fix my kurzweil pc 88 ... no function just powers on but no display...need help urgent
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 01, 2012 | Computers & Internet
I have a dell monitor 1703 FPt connected with my notebook. However I cannot find the monitor driver to have the monitor display perfectly. I downloaded one driver R57788, it is Analog instead of Digital....
Hey there! Sorry about that.
Seems you've got a problem that you can't fix yourself, and I could help however, I need to self diagnose the monitor. But since I'm not there in person, you'll have to contact the service centre and have them fix it up.
Monitors can damage your eyes if its not in the right version of hertz. Please try fixing it ASAP
I hope that I helped you & that this post helps you at most! Don't forget to rate! =) marinora_43.jpeg
Jan 15, 2011 | Dell 1703FPt 17" TFT LCD Flat Panel...
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
Viewsonic monitor goes black one second after startup screen boots up. Fix for this? thanks
plz log in safe mode and then disable the display adapter from the device monitor then log back normally and check whether problem is solved or not
Apr 29, 2009 | Computers & Internet
Monitor screen is black
bad capacitors on the power board internal to the monitor they need to be replaced.
Mar 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Acer x223W Monitor issue - not displaying correctly in native resolution
hi, when all connected press and hold the FN key on the bottom left of the keypad while pressing one of the function keys F1 to F12(the one with picture of a screen or monitor). You may need to press it more than once but if will eventually switch the display over to the tv
Hope this help
May 30, 2008 | Acer AL2216WBD LCD Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
