Question about VIA Epia M860-12e Fanless Mini-itx Embedded Mainboard
My embedded board of model EPIA-M860-12E is running but it is not showing desktop screen.May I know what's the problem is?What should I do?
It shows the board is not compatible with the monitor.
  • 3,799 Answers
In which case change the monitor. I have checked the spec of the board and it has a VGA connector and should output to a normal VGA monitor. But your system is designed for Point of information and industrial automation. Try and find a display made for these purposes.
Posted on Dec 06, 2012
It's impossible to get into BIOS setup on an epia-m
not all boards use the delete key, try these alternatively f1,f2,f5,f12 let me know if you have any luck! cheers
May 24, 2014 | VIA epia-m - 1.0ghz 256mb Dvdrw Mini-itx...
Tip
Reflash Via EPIA-M 1000g BIOS when board is dead
I'm writing this in the hope that others like me can resolv their problem with the dead EPIA-M mainboard.The symptoms where.. on power-up .. it would make 2 high pich beeps followed by 2 low pich beeps..turned out that is the error code for dead BIOS.
OK so u have a dead bios and a mobo that won't boot for various reasons.. from flashing a wrong or corrupted bios or else.
Apart from the other ways to go around the problem like buying a new chip already flashed or flash the chip with a dedicated flasher u can follow on this simple guide.
You should at least have some experience in DIY in computers .
1. Find a mobo of an old  pc that uses the same socket for the bios chip.if it uses award bios even better.I used a biostar p4m800-m7a mobo to do this.
No need for it to have a hdd or something special attached to it.. power source and cd or dvd/rom will do.
2. Try to see if it boots, if all ok..
3. Get you hands on the Hiren's boot cd..burn it and boot from cd..it has in the Dos program list... in the next page BIOS/CMOS UTILITIES. Select uniflash 1.4.. i did it with the 1.4 on the hiren's boot cd 10.1 maybe if they update it it will work also.It will tell you the name of the bios chip and some details..make a backup of original chip just in case.
4.On other pc download the 109.BIN file .. the bios file known to be stable for the EPIA-M board. You can find it on some forum.. i can't remember now..I thank them by the way.Same the file on a fat32 usb key.
5.On the surogate board with uniflash started.. comes the tricky part: u have to get hold of some good tools and pull the bios chip out while it's running... don't worry, nothing will happen.
6. Pull out the dead bios chip of EPIA-M and put it in the surogate board.These steps must be done with absolute care.If you think you can't do it, wait or call a friend with more experience or get hold of the right tools
7. Now with the dead bios chip in place.. select in uniflash, rediscover bios chip.. or something like that,..can't remember well.. but you get it when you see the screen... the sst bios of the EPIA-M NOW SHOWS UP...
8. select flash bios and select the file on the root of the usb key by typing C:\109.bin.. if no hdd attached.. the key is seen as C, otherwise use letter accordingly.It flashes the bios in less that 10 seconds.. and says ok.. power off surogate mobo.. replace bios chip with original.. and enjoy now your EPIA-M mainboard again.
If you'd like to thank me or ask details..mail me at www_offspring@yahoo.com
on Jan 19, 2012 | VIA Epia M10000 Motherboard
Graphics not run
Go here for info and drivers : http://www.via.com.tw/en/products/embedded/ProductDetail.jsp?id=81
Hope that helps.
Cheers from NZ
May 23, 2011 | VIA EPIA 10000 1GHZ Nehemiah (EP10000N)...
I sent i a question yesterday .Still I'm unable to
If the screen shows running in lower power as an error. I think your powersupply isn't supplying enough power to the computer, and probably needs to be replaced.
May 11, 2011 | Gateway Computers & Internet
I turn on my HP Pavilion a1610n PC Desktop everything lights up but it doesnt show anything on the screen, all the fans are spinning the front lights are on and i know its not the screen cause it works for...
You may have a faulty video card. Test this card with a know working pc. If your video is embedded on your main board, try using a PCi video card.
Good Luck.
C2Solutions
Jan 22, 2011 | HP Pavilion a1610n PC Desktop
I pulled the jumpers off the audio pins on the
Go to this page on the via website, towards the bottom you'll find a link UM_EPIA-M_150.pdf
which is the manual for the epia motherboards
Apr 12, 2010 | VIA Epia M10000 Motherboard
Ethernet suddenly not working VIA EPIA-MII10000 Motherboard
I need mother board driver for computer emachines t3882
Dec 27, 2008 | VIA EPIA-MII10000 Motherboard
VIA Epia M860-12e Fanless Mini-itx Embedded Mainboard Logo
202 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
