Question about LG 50PA4500 50" 4500 Series Plasma HDTV
Won't power on
After going into Settings and auto-updating the channels, my TV powered off completely and now will only stay in a sort of standby mode where the red power light will be on but the TV itself won't display anything. Every time I press the power button it makes a clicking sound, the red light goes away for a second, and then it comes back and stays solid. I've tried switching out the cables and trying different electrical outlets. I don't understand what could have gone wrong here. Please help.
  • LG Master
  • 928 Answers
Sounds like a Zenith or LG TV. It is most probably the Y board, when you hear the clicking sound is usually that. I am sharing this with you because it happened to me with a Zenith (POS). The red light (on my TV) is in the bottom right corner. In my case it was the Y Board. Best of luck
Posted on May 15, 2017
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
jdvillanueva
  • 2098 Answers
SOURCE: I have an lg plasmas model # 42pc5d-uc\r\nthe tv
Hi Paul,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Secondary reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 01, 2011
Testimonial: "thanks....."
SOURCE: TV always in standby mode and can't display channel. Need press many times
Go to Badcaps forum online
Posted on Dec 07, 2011
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
Tv won't power up straight away
when lcd tv`s fail to power up, but stay on standby. It is usually because of bad capacitors on the power board. My 22" lcd monitor did the same. It would not come off of standby. It starts with them being slow to turn on. "Sound familiar"? I fixed mine by changing the bad caps. There were two of them.
Jan 31, 2013 | Wharfedale LP160DTRHDMI
Auto standby
You didn't supply the Computer make, model or the OS you are using? The best solution I can give without more info is, Open Control Panel, Power, Change power settings to High Preformance, Set Sleep to Never, Hibernate to Never, in Advanced Power settings, Set ALL settings to your preferences.
Jan 01, 2013 | Computers & Internet
Dish Box turns itself off every night and not back on.
C Dunn,
I can definitely provide assistance with this. Whenever our receivers do their nightly update, the receivers do enter standby mode. There is no way to disable this, but you can definitely setup an Auto Tune timer. This will cause the receiver to exit standby mode and tune to a channel.
To set this up, find a channel you want the TV to go to, and choose the time you want the receiver to turn on. Press record from the guide. Select 'Auto Tune' from the list, and select 'Daily'. This will set it up to happen every day.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Nov 27, 2012 | DISH Network ViP622 DVR DTV Receiver /...
MY TV WONT GO OFF STANDBY
if you didn't set it it won't go to standby
Sep 27, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I rescanned the channels after our area has gone digital and this went OK but now the TV won't come on and the standby light just keeps fashing as though its trying to come on. I left it all last night...
You did the opposite of what might be useful. Completely cut of it's AC supply, pull the plug out of the socket and leave it like that for 10 minutes.
Plug back in but first making sure the manual power button is off on the set, not in standby mode.
(pushed in)
Then push the manual button to restore standby mode and switch set into full on mode with the remote.
It will either have "rebooted" and work straight away or you'll need to put it into Auto Set Up mode.
Proceed as the first sections relevant from the instructions.
Sep 22, 2011 | Televison & Video
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
LG 50PA4500 50" 4500 Series Plasma HDTV Logo
41 people viewed this question
Computer Repairing
Computer Repairing
