Question about Canon iR 2016i Black and White Copier
Change papaer size and frequent papaer jams
Hi, i am working on a iR2016 DIGITAL copier and i have the following problems:
1) anytime that you are about to make a copy, the LCD of the machine displays change paper size but the paper size dial is still at A4 or at time during or after you have made copies.
2) When you give a copy command, the machine is unable to pick papers and displays paper jam. At times when you give a command to copy about 10 copies of a document, it will print about 3 or 4 and the LCD will display paper jam. when you open the left cover there will be no paper stacked in the machine but it will still display the same problem. I have changed the paper pick up rollers and the problem still persist.
Kind Regards
Nat
  • 2 more comments
  • Nathaniel Eric Mensah
    Nathaniel Eric Mensah Jan 13, 2009
    Hi jpd8,
    i am in Ghana west Africa.
    the normal size of paper we use is the A4 size of paper.
    thank you.
    Nat
  • Adi_Taticu
    Adi_Taticu May 11, 2010
    i want to know if the problem persist.
    There is a solution
  • Carlos Perez
    Carlos Perez May 11, 2010
    so i assume you want to work with the A4 size right? so you changed the knob in the Tray and then adjusted the limits? make sure the limits are set as the image shown in the kbow for the selected size. they must match, if Auto size detection is set on then when you put the original it should be recognized. if not then try to manually select the paper source for your A4 tray and try make the copies. if still doesnt work and you said you have aklready changed the opick up rollers try cleaning the other roller (separation) and give it a try. if the paper is not even picked up then you might have an electronic issue with a solenoid.
  • jpd8 May 11, 2010
    What country are you in? US machines should not be set to A4.
  • 1,219 Answers
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Posted on Jan 12, 2010
Testimonial: "yes, you are smart. it was the clutch"
    New Friend:
  • 18 Answers
Check the clutch registration
Posted on Mar 14, 2013
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Apr 02, 2012 | Toshiba Office Equipment & Supplies
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
Canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Nov 30, 2008 | Canon CLC 1140 Copier
Canon iR 2016i Black and White Copier Logo
292 people viewed this question
old marine
old marine
