Question about NeoWave PC Audio Graphic Equalizer External Sound System
Look for sound driver for motherboard Intel GTL+ 64-bit 367 MHz
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Need to get sound card working on intel S3210SHLX motherboard... Any cards that work ???
Try using this link:
http://www.intel.com/p/en_US/support/detect/
This utility will find the driver for you.
Or find the driver manualy from here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22S3210SHLX%22
The slot type is following:
One PCI Express* x8 with x 16 connector
One PCI Express* x 8 with x8 connector
Two PCI-X 64-bit/133 MHz
One PCI 32-bit/33 MHz One PCI Express* x8 with x16 connector
One PCI Express* x8 with x8 connector
One PCI Express* x 4 with x8 connector
Two PCI 32-bit/33 MHz One PCI Express* x 8 with x16 connector
A creative sound card, PCI type will work
Hope this was helpfull.
Mar 14, 2011 | Intel Entry Server Board S3210SHLC -...
The sound on my L7VMM2 motherboard is not working.
First of all which operating system is on the machine?
Secondly have you been into the BIOS to see if the on-board has been disabled. To get into the BIOS restart the computer and press either the Del or Esc key to access the BIOS.
Also go to device manager and see if the audio has been disabled from there.
If you have installed Windows 7 or Vista then there could be a chance that the motherboard drivers are not designed for the operating system. If that's the case then no driver will work.
You would have to manually search the internet for someone who may have found a compatible driver.
Regards.
Jul 22, 2010 | EliteGroup Computers & Internet
Sony Driver
Without the model number the above is meaningless.
Jul 30, 2009 | Sony Computers & Internet
SONYVAIO-PC
You dont need any driver since your PC is configured as x64 bit processor so all you got to do is get hold of the XP OS which is meant for x64 compatible PC's. The one normally used is 32 bit named as x86. I hope u wont face any difficulty in getting hold of x64 based OS(XP)......sodeep
Jul 30, 2009 | Computers & Internet
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Large hard drive
Yes it will. Mostly it is the operating system that will allow the drive to be see at its full size. Suggest you use Win XP home with at least SP1 but Win XP Pro with SP2 is faster & very stable. Also suggest you set the drive up with the Mfg's disk utilites. Bootable floppy or bootable CD. If using plain XP home you can still install the OS & than download a free trial of Partition magic which will allow you to combine any smaller partitions to get you up to you 250GB size. (only if you have a problem though.
Feb 26, 2008 | Intel Motherboard
Motherboard Drivers
What make is your motherboard? If you open up the case and there should be info and model number on it. The just go to the makers website a get appropiate drivers.
hope that helps :)
Dec 29, 2007 | Computers & Internet
NeoWave PC Audio Graphic Equalizer External Sound System Logo
439 people viewed this question
Top NeoWave Computers & Internet Experts
David Payne
David Payne
Are you a NeoWave Computer and Internet Expert? Answer questions, earn points and help others
